So, I got the bug to build a one tube regenerative radio.
I found a design from 1940 that looks promising.
Question ... what capacitors do I use?
There are only three ... a .0001 MFD ... a .0002 MFD ... and a .5 MFD
The first two are Mica and the third I am guessing was paper.
The radio should cover the SW bands ... so say 1.8MHz to 30 MHz
What is the modern equivalent caps?
I am also having a bit of problems finding the choke ... I am thinking maybe I can wind one? Might also be a bit of a rabbit hole ... started reading about RF winding (Pi winding) and litz wire and ....
Thanks so much ....
Thanks so much ....
