What amperage/speed is this motor?
Cyrus Mingley
Joined Apr 18, 2020
92
What amperage and or watts would this (universal?) motor use? It’s a weed eater motor rated at 120v but I’m not sure the draw/speed/noise of it. I have a switch rated at 120v 18amps and want to confirm this is safe to use with it. I can’t find anything online about the motor, except one product that’s a different serial number but it looks identical. I can’t find any information on it however. I’ve included some pictures of it for reference. Any help is appreciated!!
BillB3857
Joined Feb 28, 2009
2,573
The motor appears to be one from a vacuum cleaner of some sort. Those motors are usually a series wound, brush type. The speed of a series wound motor is limited by the load, otherwise, they will self destruct due to overspeeding.
Cyrus Mingley
Joined Apr 18, 2020
92
Got it, this particular one is from a weed eater so will it do the same?
Reloadron
Joined Jan 15, 2015
7,926
No way to tell. It's 120 volt 60 Hz and that's about all we know. It's small so a fractional HP. Looks to be driving a pump impeller and is obviously a brush type motor. If it were run under normal load conditions and the actual current measured that may help give some rough idea. It looks to be a "universal type" design and the com could be cleaned and maybe brushes replaced. Universal design as found on many old electric drills and it will likely run on AC or DC. They run at higher speeds than for example an AC Synchronous motor. However as to current and speed no easy way to know.
Ron
Cyrus Mingley
Joined Apr 18, 2020
92
Awesome, thank you. I planned to use it to make a homemade lathe, so what type of load am I looking at? The lathe would be more for sanding small things with a file and not so much turning a large chunk of wood.
Cyrus Mingley
Joined Apr 18, 2020
92
Ron
MaxHeadRoom
Joined Jul 18, 2013
30,804
All series motors should always be operated with a load of some kind or otherwise stop them from exceeding the rated RPM, as mentioned, these operate in a runaway condition and it is only the load, windage or friction that limits the rpm.
IOW, with no load it will produce very high rpm with very little current.
Not a good idea on a lathe if this is the spindle, unless you monitor the rpm and control the motor this way, look up SUPERpid.
Max.
Cyrus Mingley
Joined Apr 18, 2020
92
Max.
Great, thank you. Since it was a weed eater, what/how much load was stopping it from just going and going?
BillB3857
Joined Feb 28, 2009
2,573
Any series motor I have ever seen had a fan attached directly to the motor shaft. An old timer told me that the fan was to provide a minimum load to the motor and prevent a run-away condition.
MaxHeadRoom
Joined Jul 18, 2013
30,804
You most likely have blocked the end of a vacuum at some time or other, you can hear the results of the motor RPM drastically increase due to removal of load.! ;)
Max.
