What am I missing on my interpration to the following circuit?
BobTPH
Joined Jun 5, 2013
11,678
Do you know how to read a schematic? If so, look closely at yours from the original post.
Can you see that the 3 LEDs and their resistors connect to the same point on both sides?
If you can see that, can you see how they must be all on or all off at all times?
If you don’t understand any of this, please ask a specific question and maybe we can get you there.
atferrari
Joined Jan 6, 2004
5,032
Prior to returning the Rosetta to Egypt, I think I started to understand what is his idea based on the following
The next step is to try it out with 6 LEDs. Suppose each LED is labeled as below
LED 1: AB
LED 2: AC
LED 3: AD
LED 4: BC
LED 5: DB
LED 6: CD
You have a bunch of LEDs and each LED belongs to one or more sets.
The OP should create a simple block diagram showing those sets and then go for the actual detailed switching scheme with no relays.
