Weird Output with MultiSim 13.0
Zeeus
Joined Apr 17, 2019
616
connect the 2 points marked x in U3B and then no problem if you expect output to go to negative rail :)
btw, welcome to AAC!
Murray Chen
Joined Jun 12, 2019
11
First, thanks for your Greetings.
MultiSim do not allow to connect redundant rails to the same component
(U3A and U3B, in this case).
For your suggestion, I changed U3B to U4A, but got the same results.
