A weird one...
Externet
Joined Nov 29, 2005
2,681
My bedroom:
A TV hung on a wall. A ceiling fan on a wall switch. Both in the same breaker circuit.
Often, TV reception over the air gets pixelation or no reception at all with fan on low speed. Gets fine at high speed.
:oops:
WBahn
Joined Mar 31, 2012
33,316
My bedroom:
:oops:
Very rough guess, the noise produced by the fan on low speed is at a frequency that isn't getting filtered well while the high speed noise is.
WBahn
Joined Mar 31, 2012
33,316
No triacs, no dimmers. Just a plain wall switch. Stock everything, nothing modified. :oops:
But, inside that thing, there is some means of changing the speed and if it uses triacs, those will generate quite a bit of noise to produce the low speed whereas if it is effectively connected directly to the mains at high speed, that noise will be absent. I suspect that Ian0 has hit on the core source of the behavior.
Externet
Joined Nov 29, 2005
2,681
Have not opened it; Another fan like that has 3 capacitors in one package to select the speed. I think they go in series with a winding for the 3 speed selection.
