The + input of U3B is connected to what? 4.2V?
You connected the rails of U3A, you connected for U3B too?
Yes, the + input of U3B is connected to 4.2V.The + input of U3B is connected to what? 4.2V?
okay but it can connect? if it can then connectYes, the + input of U3B is connected to 4.2V.
For U3B, it no needs to connect to rails, because U3A and U3B are in the same component.
First, thanks for your Greetings.connect the 2 points marked x in U3B and then no problem if you expect output to go to negative rail
btw, welcome to AAC!
It can not. These 2 red cross marks are brought out by MultiSim itself and means not necessary to connect to rails in this case.okay but it can connect? if it can then connect
oh sorry...you can make 1 more stupid change?It can not. These 2 red cross marks are brought out by MultiSim itself and means not necessary to connect to rails in this case.
what's circuit for?Although it works with LM358P, but can not cease my doubt.
(Because I've simulated the original circuit with Altium Designer and OrCAD, they both did well without any problem.)
Part of 18650 battery charging system.what's circuit for?
