Isaiah Gerald
Joined Aug 19, 2020
17
Hi! I Have a transformer that has a 0V 185V 220V 255V Marking on the primary side and 7.1V 0 7.1V and a low power 19V
unfortunately i dont have a tester to check the transformer's 220v input and i dont wanna just plug it to mains because im pretty sure its gonna cause chaos, pls help! The Transformer's markings:
C.B8.0190600
2014 06 25
EA03-105N/EA305N
Pictures: I dont have a camera so i found the exact transformer online
https://www.amazon.co.uk/SATYCON-Transformer-UPS-Model-CB80190900/dp/B075KJ7538
Also i tried to search for its datasheet and i found nothing :(
ericgibbs
Joined Jan 29, 2010
21,649
hi IG,
Welcome to AAC.
It looks a regular type mains transformer.
Can you measure the gauge of the wire on the secondary windings also the central cross section of the transformer core in inches.
We can then guestimate the ratings.
E
Alec_t
Joined Sep 17, 2013
15,167
Welcome to AAC!
If you have a multimeter, measure the resistance between the 0V terminal and the 220V terminal and report back.
Isaiah Gerald
Joined Aug 19, 2020
17
hi IG,
Welcome to AAC.
E
0.3 Inch on the thick secondary winding
and 0.1 Inch in the low power winding
Top Side 3 Inches
Side 4 Inches
Edit: I Got This from a UPS which has no model number
ericgibbs
Joined Jan 29, 2010
21,649
hi,
I would say the centre tapped 7.1v.0v.7.1v is for driving a rectifier circuit suitable for charging a 12V SLA battery.
The 19v is for the charger regulator and control circuit.
The 0.3inch measurement sound incorrect.??
As you have no test equipment what are you planning to do with this transformer.?
E
Isaiah Gerald
Joined Aug 19, 2020
17
hi,
E
I Ordered a multimeter today and it will be arriving tomorrow so ill basically make a 12v battery charger
Ofcourse ill implement auto cutoff and other protections
Edit:I don't know why but i measured or converted the secondary gauge wire thickness wrong The actual thickness is 0.125 for the beefy wires
the 19 volt wires is 0.050
Isaiah Gerald
Joined Aug 19, 2020
17
I
hi,
E
Is Using a multimeter mandatory to know / identify the input voltage wires?
MaxHeadRoom
Joined Jul 18, 2013
30,885
A meter is not gong to do much to detect anything without putting it under power.
You have all the data on the transformer, why not connect to 240v and see what happens?
The worst that can happen, if faulty, is it will either trip the breaker or get hot very quickly.
It sound as though you are new to electro/electronics?
Max.
sagor
Joined Mar 10, 2019
1,056
Why does the link to the transformer ad say "UPS 650" ?? Could it be a replacement UPS transformer. The 7.1-0-7.1 could be a 14.2V switched primary (battery), to produce the mains voltages.
Mind you, these can usually run "backwards" as well, to produce low voltages.
Just thought I'd bring up this point, everyone is assuming it is a 220V mains primary, maybe so, maybe not...
Isaiah Gerald
Joined Aug 19, 2020
17
Yes it is, i got it from a ups with a model number of Bosline EA 650VA which i can't find the datasheet of
Isaiah Gerald
Joined Aug 19, 2020
17
it is 220V and Backwards Compatible, In the UPS there is an Inverter Circuit problem is its broken that is why i didn't just use the ups's Charger Directly
Isaiah Gerald
Joined Aug 19, 2020
17
Max.
Yea umm tried that with another UPS transformer and it didnt trip the breaker and kinda just smoked
Isaiah Gerald
Joined Aug 19, 2020
17
Guys i found the exact same transformer here maybe this can help?
edit: its not english so can anyone learn from this or translate it?
