weightsensing project using arduino
damilarem
Joined Aug 5, 2017
41
i av done d coding part and my sensor is sensing values.. but i keep seeing errors and d tolerance is too wide.... and d values keep changing..
this is my code hope u help me speedily.. i also wanna incorporate keypad to tare change values and d rest
Code:
#include <LiquidCrystal.h>
#include "HX711.h"
#define sw 2
float temp_reading = 0;
HX711 scale(A1, A0);  // parameter "gain" is ommited; the default value 128 is used by the library
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
void setup()
  lcd.begin(16,2);  // initialize the lcd
  lcd.home();
  lcd.setCursor(0,0);
  lcd.print("HX711 Loadcell");
  lcd.setCursor(0,1);
  lcd.print("Zeroing ...");
  delay(5000);
  scale.set_scale(-583.3f);  // this value is obtained by calibrating the scale with known weights; see the README for details
  scale.tare();  // reset the scale to 0
  lcd.clear();
void loop() {
  lcd.setCursor(0,0);
  lcd.print("Weight");
  lcd.setCursor(0,1);
  temp_reading = (scale.get_units());
  if (temp_reading <0 )
  temp_reading =0.00 ;
  else
  lcd.print(temp_reading ,2);
  lcd.print(" Gram");
  lcd.print("  ");
  scale.power_down();  // put the ADC in sleep mode
  delay(2000);
  scale.power_up();
Moderator edit: added code tags.
ericgibbs
Joined Jan 29, 2010
21,555
hi d,
I downloaded your Sketch. modified it to use the Serial display, made some other changes.
Used a Calibrated weight of 500gm and 60gm, the list shows the outputs.
The lines marked 'add' are where I was placing the test weight on the load cell.
How accurate are you expecting the final weights.??
Rename the text file to .ico for Arduino
I would advise you not to suppress weights below zero and display 0.0
E
Code:
#include "HX711.h"
#define sw 2
void setup()
  Serial.begin(38400);
  Serial.println("HX711 Demo");
  Serial.println("Initializing the scale");
  Serial.println(scale.read_average(20));  // Display the average of 20 readings from the ADC
  scale.set_scale(146.73);  // this value is obtained by calibrating the scale
void loop() {
  Serial.print("Weight=");
  temp_reading = (scale.get_units(5));
  Serial.print(temp_reading , 2);
  Serial.print(" Gram");
  Serial.println();
  delay(3000);
damilarem
Joined Aug 5, 2017
41
THANKS D MUCH E MAN .... I HAVE DONE WHAT U SAID TO THE LETTER I DISCOVER THAT THE READINGS IS GIVEN ME NEGATIVE VALUE AND IS NOT STABLE STILL.. THE SET.SCALE VALUE I CHANGED TO -146.73 IS NOW GIVEN POSITIVE VALUE..... BUT STILL NOT STABLE .. IT FLUCTUATE FROM AROUND +5% OR -5 %
ericgibbs
Joined Jan 29, 2010
21,555
Can you post a photo of the project, showing the wiring etc.
What is the maximum weight that you want to weigh.?
What calibration weights are you using.
I need a lot more information so that I can help you.
E
