Waveform Generator Problem
32,823
It is incorrect to say that the inputs of the first opamp are at virtual ground. The term "virtual ground" means that the voltage is 0V (i.e., the same voltage as your "ground") even though that node isn't connected to ground. That is not the case here. These two nodes can be at a voltage other than 0V, but they have to be at the same voltage even though they are not connected to each other. This is known as a "virtual short". The distinction is important.
MikeML
5,444
That is not correct either. The first opamp is acting as a multivibrator, so the inputs are almost never at the same voltage...
38,503
That's true if the op amp is operating in the linear mode but here it's operating as a comparator in a square-wave relaxation oscillator circuit, so the two inputs are only at the same voltage at the instant the output changes state.
Edit: Okay, Mike beat me to it. ;)
32,823
f=\frac{1}{T}
T=\frac{1}{f}
f=82 Hz
Find T.
T is known.
R3 is known.
Find B.
Plug everything in and solve for C1.
T=2*tau*ln\frac{1+B}{1-B}
tau=R_{3}*C_{1}
B=\frac{R_{1}}{R_{1}+R_{2}}
Wouldn't it be even more helpful if you wrote up the entire solution and submitted it for the TS?
shteii01
Joined Feb 19, 2010
4,644
The dude is too clueless. Me solving this one little problem is not going to make him finish that class with an A. I will be very surprised if the dude can get a B for this class. My bet is on C or D.
callum2510
Joined Aug 26, 2015
9
I wasn't looking for a answer more an explanation. Why have a homework help section on the forum if you ***** are going to criticize me asking for some help?!
callum2510
Joined Aug 26, 2015
9
How the **** would you know what my academics capabilities are? Yes some questions are challenging for others hence why I approached this forum for clarification. You're just an old American wanker that loves to assume stuff without any knowledge
32,823
Watch the language -- that will get you banned pretty quickly.
I wasn't criticizing you at all -- I was making remarks aims at shteii01 (i.e., the person whose post I was responding to).
32,823
The you are always free to go elsewhere. But obscene language won't be tolerated here.
JoeJester
Joined Apr 26, 2005
4,390
You thanked shteii01 and then quoted his post with no other comments.
Then you went on a rant.
Is there a question forthcoming?
shteii01
Joined Feb 19, 2010
4,644
Look. I was responding to WBahn.
Generally speaking, I was rude to callum2510. I admit it. So his response does not surprise me. However! I was rude. He was rude. I got what I deserved. The original question/homework problem was answered. Lock this thread and let us all move on.
JoeJester
Joined Apr 26, 2005
4,390
Generally threads are not locked.
It really doesn't matter who you responded to. In your second rant, you mentioned shteii01. I personally thought it was uncalled for, so I decided to ask if there was more questions. Since there's not, my time in this thread is done.
