water flow sensor yfs201 is not getting signal from atmega328 pu pin A0,
Thread Starter akshaymech Joined Jul 15, 2021 6 Jul 22, 2021 #1 water flow sensor yfs201 is not getting signal from atmega328 pu pin A0,
ericgibbs Joined Jan 29, 2010 21,542 Jul 22, 2021 #2 Hi a, We need more information, diagram, program code etc... E
DickCappels Joined Aug 21, 2008 10,662 Jul 22, 2021 #3 There is no PORT A on the ATMEGA328. Pin 2 is D0. edit: If you are using pin 2 be sure it is configured as an output in Data Direction Register D. Last edited: Jul 22, 2021
KeithWalker Joined Jul 10, 2017 3,614 Jul 22, 2021 #4 akshaymech said: water flow sensor yfs201 is not getting signal from atmega328 pu pin A0, Click to expand... RDIONO, N The signal on Analog pin 0 should be from the water flow Sensor to the ATMega328, not the other way round! Please show a schematic diagram and your coding to help us understand your problem.
