water flow sensor uses only pin 2 of atmega328?
DickCappels
Joined Aug 21, 2008
10,661
There is no PORT A on the ATMEGA328. Pin 2 is D0.
edit: If you are using pin 2 be sure it is configured as an output in Data Direction Register D.
KeithWalker
Joined Jul 10, 2017
3,618
water flow sensor yfs201 is not getting signal from atmega328 pu pin A0,
RDIONO, N
The signal on Analog pin 0 should be from the water flow Sensor to the ATMega328, not the other way round! Please show a schematic diagram and your coding to help us understand your problem.
