You need to provide better information to provide an answer.
Washing machine manufacturers use what ever color they want.
I have never came across a standard on color wiring from what I have seen among the many machines I repair
It will depend where you are in the world and your profile doesn't say. In the UK it would be against the law to sell equipment with those wire colours. Our standard requires Brown-Live, Blue-Neutral, Yellow/Green striped-Earth.
You can identify the earth wire by checking for continuity to the metal case of the machine. It won;t make too much difference which way round the other two are connected unless the machine has fuses inside in which case the live wire should be connected to the wire which connects to the fuse(s).
