Samsung eco-bubble washing machine has been frantic
abdulbadii
Joined Aug 30, 2017
91
This Samsung eco-bubble front-load washing machine has been going out of control for around one year since very beginning of issue
The starting issue is Power switch cannot or very rarely works, so if it's being ON cannot or can very hardly get shut down and vice versa
But after that's been replaced and worked turning ON/OFF normally the electronic control problems else proliferated up to now;
the eco-bubble feature keep being ON, ie. activated (recognized, confirmed by its noisy sound) no matter on what condition it's being,
even worse further, now if the washer being turned OFF, so it would get off presumably indicated mainly by its control panel goes off, but then the washer eco-bubble keep being ON and keeps sounding its noise !
Only after it's disconnected to power, here the stabilizer PS is turned OFF (might be same to getting unplugged), then the washer would get shutdown
This's ~17 years old product so still the non-inverter type washer but has had smartphone/Android remote monitor/control feature
So one has gone through such issue or know what actually the faulty mechanism is, out of the correct, normal working one, so to sincerely share it and help me out ?
the panel PCB barcode label has mark code on top;
DC92-01628D 8U-02 (210,000)
Thanks in advance
twohats
Joined Oct 28, 2015
621
Have you got the service manual?
Have you looked on YouTube?
17 years old, it's time to bite the bullet,
Good luck...........
panic mode
Joined Oct 10, 2011
5,480
Power switch is likely membrane type and after years of use button is sunk (making contact all the time) or some moisture found its way in. either way that would be the likely reasons it did not work. chances are same is happening with the other buttons.
