Wanted: MC648DLS TM board for trade, etc.
Status
Not open for further replies.
imalearnin
Joined Oct 7, 2022
13
The motor I have is 3.0 CHP with max voltage at 130 VDC / 2238 Watts.
If the MC2100 board will work with that motor, I can send you my MC1648DLS if you want.
imalearnin
Joined Oct 7, 2022
13
They typically work with 3.0 - 3.5 HP motors, it is a brushed DC, correct?
Where are you located?
Here is a pic of the nameplate. I am pretty sure it is brushed. I guess being a PMDC motor means its brushed doesn't it? I have a red wire going into one side and a black 180 deg from the red. motorNamePlate.jpgI am near Cincinnati Ohio. I am not sure if I should post address or send it to you some other way. I am not sure how that is done on this site.
MaxHeadRoom
Joined Jul 18, 2013
30,842
I want to ensure every thing OK before I send, one of these, I will send you a private msg via the 'Conversations' top right
MaxHeadRoom
Joined Jul 18, 2013
30,842
Dan I recieved the board and tested it and it works fine on the bench, was there a problem with it?
If so how did it manifest itself?
Status
