Wolframore
- Joined Jan 21, 2019
- 2,619
let’s try the good old water analogy:
Water will not flow without a difference in potential. Same with electrical current. Whether this differential is due to magnetic, heat, light or voltage, you need the difference in potential to make current flow.
I recall the conversation about MOSFETs and transistors are voltage or current controller devices. We should stay with the convention. Mosfets will trigger from a difference in potential even when this is provided through a dielectric. The BJT, however must have a constant source of current to stay switched on.
this circuit will not work for a BJT
