Curiosity question: Have this LCD. What voltage or current?
B-JoJo-S
Joined Jan 3, 2026
607
I have this LCD out of an old gauge cluster from a car. It has 16 pins. It has no markings except for four color stripes on the very edge of one side. I don't know the pin-out or what voltage it may take to activate an element or two. Or maybe it depends on current, but I think it's voltage.
This is the color bands. My color perception is not all that great so best I can say it looks like Red Blk Yel Blu. (or purple) If that helps.Screenshot 2026-03-21 at 11.58.06 AM.png
If I knew what voltage is required to activate an element I can probe line after line and note which leads produce what effect.
At the moment it's sitting on conductive foam but only for protection from damage. I just put it into the foam a few min's ago.
B-JoJo-S
Joined Jan 3, 2026
607
OK, I guess I can figure out the data pins. If not - I'll ask. But what's the LED pins? Is this self backlit? Now that I think about it - it probably is. So I'm going to guess 5V on pins 15 & 16, paying attention to the polarity.
B-JoJo-S
Joined Jan 3, 2026
607
Far right side of image 1 there's a slight bump. My first guess is it's a seal from when the LCD was made. Perhaps that's the LED ? ? ? What voltage? Can't be more than 12V.
B-JoJo-S
Joined Jan 3, 2026
607
There doesn't appear to be any intelligence on the display. So what are the data pins for? Please don't tell me "Data", I could guess that much. Is it digital? Is it a frequency of some sort?
B-JoJo-S
Joined Jan 3, 2026
607
There are no identifying marks. Which one is Pin 1? Would it be the same end as the color bands?
Nevermind. I grabbed the board it plugs into. Pin 1 is on the right side. Behind the LCD are three LED's that backlight the display. So perhaps pins 15 & 16 are for something different.
BobTPH
Joined Jun 5, 2013
11,678
That is a raw LCD. The pins are not as shown in this thread, that requires a large chip. Driving them is quite complex, it requires an AC square wave. They are also typically multiplexed.
B-JoJo-S
Joined Jan 3, 2026
607
So it's nothing I can easily use elsewhere. It's out of a Toyota Corolla. There IS a large chip (144 pin) on the board that likely controls everything. Speedometer, Tach, Fuel gauge, Temp gauge, lights and warning lights.
