Voltage vs Current Which Occurs first?
MrAl
Joined Jun 17, 2014
13,765
Current is not electrical energy, current is a rate, a changing frame of reference in space and time.
With a "changing magnetic field that will in turn create a changing electric field" what is actually changing? Magnetic and electric fields are aspects of one relativistic object. The source of the magnetic field, B, is also a source of an electric field, E. There is no cause and effect, there is only a coupled existence. In the relativistic point of view, the “magnetic field” is just an electrical field as experienced by (i.e. relative to) forces on other charged particles in the vicinity. Frame of reference separates the electric field and “magnetic” fields for the observer.
For EM radiation on the spinning battery we need discontinuously distributed charge under acceleration. IMO what we will mainly see are non-radiating reactive fields (like a generators induction fields) with very little EM radiation with the energy source from the rotation of charge. Don't assume that just because there is this changing EM field, it has to transmit energy 'far' away from the charged body.
Initially stationary, uniformly accelerated for a short period of time, and then stopped accelerating.
The EM wave is the 'kink'
So to make a very very very long story short, a DC current does not radiate energy.
Maxwell famous fourth equation added term.
MrAl
Joined Jun 17, 2014
13,765
It’s a very good theoretical model from distant observation.
Of course the model will evolve as we get closer to the object under observation. Pulsar surface gets update
For our spinning battery or dipole magnet theory, I would love to see the experiment and measurements. Even if some can guess the results without it. Always verify.
I would say the spinning battery would work to radiate energy if it was modulated.
It's interesting though to look at the unmodulated case also. There we would have circular symmetry for every electron in the package, at least on average. That would look like a whole bunch of turns of wire almost like a coil of wire except instead of a helix it would look like a lot of concentric circular paths. So i think that would constitute a DC current or a set of DC currents. Change the rotational speed however and we must see radiation (again Maxwell's fourth equation).
What else is interesting though is how would a passing object see this. IF the object was moving past the battery it would have to experience some force. This would mean that anything moving in the universe would experience a force from that rotating battery at least in the classical sense. Also, since the battery would be influenced by the gravity of any star and/or planets around it, that would mean it would be moving through the universe along with those objects. That would mean that there would be some acceleration as the battery spins because when it spins in sync with the movement it would be moving faster and when it moves out of sync it would act as a change of translational speed which is of course constitutes acceleration.
Another interesting example i did a utube video of. An electron beam oscilloscope. The beam acts like a current and has a magnetic field and the demonstration was to show how Lorentz Force. A magnet brought near to the beam causes it to deflect.
I did the experiment and video to show exactly how it works because many of the videos i found online before that had shown the effect but did not show the exact setup of the experiment. They either neglected to show the polarity of the magnet or of the current so you could not pin down the effect in exact turns.
With an oscilloscope everything is known exactly about the current you only have to make the magnet with North and South beforehand.
The video should be found on utube but it may be hard to find. It's very simple where we show a dot on teh screen and as the magnet if brought near to one side the dot moves down.
MrSalts
Joined Apr 2, 2020
2,767
I think there is some confusion as to what i mean when i say simultaneous.
I am not saying that current reaches it's highest point instantaneously. I am saying that current STARTS to flow as soon as voltage is applied. It is the start point, at t=0, that i am talking about, not 1ps later or 1us later although we could look at that too.
When you figure out your current vs voltage question, please let me know what happens first,
- Force or acceleration
- distance or time
drjohsmith
Joined Dec 13, 2021
1,630
An interesting thought you bring up
" a DC current does not radiate energy "
a DC current generates a magnetic field me thinks,
and if Im another magnet, or ferrous, and I push up against the field
I experience a force against my movement,
do you not need energy to create force ?
Magnetism is not energy, ( not least different units of measurement ! )
not thought about it before
interesting,
For a foot long battery the electrical length gives a wavelength for about 1GHz. For a reasonable RF radiator maybe 1/10 wavelength phase shift across space that's 100MHz but we'll use 1/1000 for 1MHz for an idea of the rate of change needed in the separated battery charges for retarded time EM radiation. The rotational speeds changes needed for dipole EM radiation would require a large amounts of KE for the tiny amounts of far-field energy EM produced.
https://en.wikipedia.org/wiki/Retarded_time
MrAl
Joined Jun 17, 2014
13,765
Oh sure, but it's all part of classical theory :)
Under classical theory the field extends to infinity. My replies reflect that view.
What else is interesting is that a magnetic field from a DC electrical current generated in our solar system could influence something in another solar system simply because an object in the second solar system is not moving uniformly with the generating source. That's of course not practical but interesting to think about.
MrAl
Joined Jun 17, 2014
13,765
interesting,
Oh i meant a DC current isolated in say deep space and if something comes near it it will surely radiate energy because there will be an acceleration of the object (assumed to have conductors) and we know that when coils of wire move through a static magnetic field energy is transferred.
See my example about the two solar systems above (i think the preceding post).
MrSalts
Joined Apr 2, 2020
2,767
Does this DC form a loop (completed closed circuit) or do you somehow have an isolated single straight wire in deep space and a current source on one side and a current sink on the other?
MrAl
Joined Jun 17, 2014
13,765
- distance or time
Well i did not intend this thread to be about solving this it was really to show that there actually is no first or second that's why i keep saying "simultaneously".
But if someone could show a first or second that's ok too, but it will most likely have to be a quantum mechanical explanation as classical theory states that they both happen at the same time in the body of Maxwells equations.
Someone mentioned the Plank Length i think earlier in this thread. But i think that would fall under the category of interpretation again. Just because we cant measure extremely tiny distances doesnt make them disappear.
MrAl
Joined Jun 17, 2014
13,765
I think either way although the straight wire segment is easiest to calculate the magnetic field of (from basic theory that is not from a pre-developed formula).
Alternately, feed the straight line segment from two perpendicular wires whos lengths are infinite and connect together at that infinity to form the loop. So a giant rectangular wire construction where we only look at one end segment outside of the loop.
BobaMosfet
Joined Jul 1, 2009
2,211
This is a takeoff from another thread where some people declare voltage to come first followed by current.
As you should know, each application has it's own preferred method or at least each model has it's own requirements. Also, some people are bent on declaring one way of doing it over another but is there really an overall blanket preference? I dont think so.
But i must quote one line from your post in particular:
"That is because we cannot "inject" a current - a current is always the RESULT of an applied voltage"
That's not really true except again in a theory that prefers that definition. We can also say that voltage is the result of a current that flows from one place to another.
I believe the correct way to look at this is that they both occur simultaneously. A way of looking at this is that in order to establish a voltage you must move charge, and charge implies both current and voltage. simultaneously. In other words, energy.
Now it is true that some calculations will prefer one view over the other, but i think it is easy to see how both ideas can play out in real life.
If we "apply" a voltage to an inductor, current flows, but it does not 'start' to flow after the voltage is applied, it starts immediately. But even if we look at it as 'after' then what about the capacitor.
If we "apply" a voltage to a capacitor, we get infinite current flow even with a tiny capacitance. Now we could say that you have to apply a current 'first' in order to charge the capacitor to some voltage, so that the voltage comes 'after' the current. But that' also not right, they both occur simultaneously.
Now we might go as far as to say that the "electric field" is 'first' established in a wire before current can flow. But in that view we are talking about *relative* values of current and electric field. In this case we deem a current as low as 1 femtoampere (for example) to be zero current when really it is not zero. Again it has to be simultaneous. Also we can look at how that electric field got established in the first place.
So the bottom line is that current and voltage are independent only in theory and we decide what theory we want to use.
It's ok to disagree with this but then you should have at least one physical example that demonstrates the contrary.
There is a reason Jesus wept.
MrAl
Joined Jun 17, 2014
13,765
Ha ha.
Actually the 11th commandment which was lost when Moses dropped one of the tablets was:
"Thou shall not haveth thy voltage come before thy current nor shall ye haveth thy current come before thy voltage. Thus sayeth the Lord thy God".
Then later He said:
"But hey guys drink as much beer as you want, or, ah, i mean, as thy wanteth".
Delta Prime
Joined Nov 15, 2019
1,311
You guys are real piece of work! In the best possible way.
All this talk about Mass,energy.
I bet none of you are brave enough to answer!
If mass and energy are the same thing,
how come the fatter you get, the lazier you become?
MrAl
Joined Jun 17, 2014
13,765
Obviously this thread has gone down hill!
Well a little fun here and there but i guess we should get back on point.
For example, i dont think there is any proof that weight gain necessarily leads to a lack of what we call 'energy' but that's way beyond the topic of this thread. We are really talking about electrical quantities.
