I'm the inventor/licensor for a commercial electronic device that operates at 12VDC using a wall power adapter. I plan to change the operating voltage from 12VDC to 5VDC so it can operate via a standard 5VDC USB 1.0 or 2.0 port. The 12 volt device will look exactly like the 5 volt device and will use the same input power plug. I need to use the same plug since changing it would require a new injection mold costing thousands of dollars. Is there a cheap way in the circuit board to limit the voltage so if someone plugs in the old version 12VDC adapter into the new version 5VDC device the electronics won't fry?
