Hi all, I developed this compressor/limiter for my needs (universal low requirement audio signal processing, dead batteries use). Although a mosfet is shown, it also works with a BJT, but then it's less useful due to BJT's low input resistance. It works well with low Vgs threshold voltage and, if possible, low inner capacitance mosfets. Attached pictures are the basic schematic and an example of tested limiter for bass guitar (that's why the 470 kohm resistor doesn't matter there - for normal use, when using the FDV303N, you need to reduce the input resistor value to some 10 - 100 kohm for better frequency response and also increase the value of filter capacitors several times + possibly reduce the drain resistor for shorter attack times if needed), working from some 0,8 - 0.9 volts (the trimmer is to set the drain voltage to half of the supply, but it's not really necessary, only at low supply voltages). Depending on the diodes used, resistors can be connected in series with the output diodes to reduce the inrush current (instead of the resistor at the supply branch). The typical drain resistor values tested were 47 - 1000 ohm (it must be quite small because of reasonable attack time), the filter capacitor values were 4.7 - 100 microfarads and the input resistor values were 10 kohm to 1 Mohm.
