Voltage follower - OPAMP
xxxyyyba
Joined Aug 7, 2012
289
It is well known that Voltage Follower (Buffer Amplifier) can be used to connect high resistance voltage source to load. We are limited with output opamp current, so there is limited range of resistances we can connect at output. Can we modify circuit on some way to expand this range?
MikeML
5,444
First, look at the opamp's data sheet for max source and sink current at specified Vol and Voh.
You can buy special opamps that can source and sink up to several Amps.
OBW0549
Joined Mar 2, 2015
3,565
33,326
This sounds like it is directly a homework problem, especially starting off with something like, "It is well known that ...." Now that's perfectly fine, but ideally, you should have thrown out your thoughts on what the answer might be. Of course, in this case you were saved that whole part of the process since someone answered your homework question for you.
