Voltage Divider
Steve1992
Joined Apr 7, 2006
100
Vout = Vin x R2 / (R1 + R2)
If Vin is 12V and I want Vout to be 4.5V
What would the equation/math be to find the values for R2 and/or R1 if given.
If R1 is given R2 would be a common factor?
21,225
[post=16871]Quoted post[/post]​
There is no unique solution. There must be some other condition. For example R1 + R2 must be 20K Ohms. Now there is a unique solution because you have two equations and two unknowns.
radiosmoke
Joined May 30, 2006
17
Et = 12v
you need to know the current. so use .1 amp arbitrarily.
It = .1amp
find R1 and R2
by using Rt = Et/It or 12v/.1amps
= 120ohms total resistance
if you want 4.5 volts then R1 = 4.5v-12v = 7.5v drop
7.5v / .1amps = 75 ohms = R1
4.5v / .1amps = 45ohms = R2
the same curent flows through both resistors. so that is used to find the total resistance
and ratio is used to find voltage drops
and resistances are in proportion to current.
