Moving clockwise around the circuit from the left hand side, the current in the resistors is I1 = 0.000163A and the voltage drop is V1 = 1.63V, I2 = 0.000163A and V2 = 3.26V, I3 = 0.0000822A and V3 = 4.11V, I4 = 0.0000811A and V4 = 8.11V. I used Kirchhoff's laws to calculate these values.No, it is not correct. Those are not the voltages you need. You also need to use resistor values that are much smaller than the resistances in the original circuit.
Forget about the voltage divider for a moment. Analyze the original circuit and figure out the voltages at each node and the currents in each branch. THAT is your starting point.
The potential across battery 1 is 0V to 8V, battery 2 is 6.37V to 11.37V and battery 3 is 4V to 0V.
What would my next step be?
