voltage divider rule application
christw16
Joined May 31, 2018
21
According to voltage divider rule: V L = RL*VS /( RL +RS ) the formula in the picture
1. Are the results identical using 1k Ohms and 100 Ohms as RL? Why?
2. I am wonder that can I use this method to measure the Rs of the microphone or the power supply or the batteries?
if can , how to implement it
thank you
MrAl
Joined Jun 17, 2014
13,780
thank you
Well did you try to calculate VL using your formula?
The formula looks right, so all you have to do is calculate once with 1k and a second time with 100 ohms.
Try that and then see if you can answer question #1.
christw16
Joined May 31, 2018
21
thank you for replying me, my answer is by the formula , the result is identical
is that right?
And I have no idea to solve second question
thank you for answering me
WBahn
Joined Mar 31, 2012
33,109
is that right?
Let's say that Vs = 10 V and Rs = 500 Ω.
What do you get for Vl when Rl = 100 Ω?
What do you get for Vl when Rl = 1 kΩ?
Are these identical?
