Hello everyone,
I built very simple boost converter. It works pretty well. I thought I understood the working of the circuit until I checked the circuit with scope.
The blue curve corresponds to measurement across collector and emitter. The yellow between base and emitter. I thought whenn one signal turns on the other one would turn off. Both the grounds of scopes were connected to negative terminal or emitter. But, here both seems to turn on at the same time but in opposite direction. I am bit confused. Can someone explain how this works.
What is this circuit called boost circuit, flyback converter?
