Hi I'm trying to build a circuit that will multiply the input voltage by a factor of 5.
Here is what I came up with:
When I use a PWM signal of 0.5 ON, the output is about double the input so it works fine, but when I change to 0.8 PWM ON, the output doesn't change much (increased by 0.2V).
Any of you have suggestions?
