VHDL - delay before switching...
pmd34
Joined Feb 22, 2014
527
I'm a bit new to VHDL, i am using quartus prime, and ultimately a MAXII CPLD device.
I want to make some VHDL code for a half bridge fet driver, so I want to switch one output off.. wait some ns.. then switch the other output on.. I would prefer to do this without using a global clock signal if possible.
I'm a bit unclear how to do this in VHDL can I use WAIT, TRANSPORT or... ?
It is also unclear to me if these are "real" delays that will be inserted into the timing when I program the chip, or if they are just simulation timings, or visa versa.
kubeek
Joined Sep 20, 2005
5,794
as far as i remeber delays like that cannot be synthesized into real hardware. How long is the time you want to wait?
s
pmd34
Joined Feb 22, 2014
527
A few micro seconds I guess.. basically I want to be able to program in a time delay between switching one fet off and the other on to prevent cross over, but I may end up with a variable clock frequency else where on the chip...
I was thinking I might simply have to add in a use of a timmer with say the on chip oscillator.
kubeek
Joined Sep 20, 2005
5,794
I would just go and implement a counter circuit that will wait for some number of clock cycles and then set the output.
pmd34
Joined Feb 22, 2014
527
Yup I guess its the way! Many thanks!
Actually I wonder if I might pick your brains whilst on the subject.. I want to do some high speed PWM with the CPLD.. I see most don't actually have very fast oscillators built in. Is there a reason for this? And any reason why it would be bad to have high speed clock module externally to supply the signal.. eg. a 100MHz oscillator module?
kubeek
Joined Sep 20, 2005
5,794
Ok many thanks for the help!
No problem, feel free to ask. My vhdl is very rusty and verilog just a bit less, but I think the major ideas of how it works are still there.
Does your IDE have a simulator that can verify the timing after the gates are placed on the cpld?
pmd34
Joined Feb 22, 2014
527
Much appreciated! To answer your question... probably! :pIm using Altera Quartus Lite, and sort of only just getting to grips with it. I have managed to figure out how to run the VDHL simulation part but I guess I am not SO confident that I know where simulation and reality will differ!
