MaxHeadRoom
- Joined Jul 18, 2013
- 30,890
Every Make of VFD I have used has both LV Input and output which are programmable. ??Post #17 does not even pretend to hint as to how one set of 3 phase connections feeding both a motor and an electrically released brake can at the same time provide the power to release the brake and at the same instant power a gentle startup to the motor.
The reality is that first, enough power must be fed to the electrically released brake, and then a much reduced amount of power must be applied to the motor to provide enough torque to start it moving.
It is not clear to me as to how two different voltages can be present causing two different current levels to flow in the same wires at the same time.
So the initial error was to connect both the motor and the brake in parallel. They need to be separately controlled.
This is separate to the VFD 3ph control, but each can be sync together in some way. The output usually offers both transistor collector output & Relay contact.
I intended to indicate that any power source present, could also be connected or switched by one of these output sources. Brake control etc for e.g.
In this case I do not see why the brake cannot be switched on/off when the Drive is at zero RPM, this is a very common application in many of the different VFD's I have used.
In the case of a brake, it is released internally as soon as the motor has a detected move trajectory..
