AlbertHall
- Joined Jun 4, 2014
- 12,652
Turn the range switch clockwise to 200k or 2000k. The range you have selected measures up to 200Ω and your skin will be a lot more than that.
Wet your fingers... a little contact-lens saline solution will do the trick.... another technique would be to prick your fingers with the MM's probes... though that would be a little painful.Hi again! Please, I'm trying to measure my skin impedance with a multimeter... But it's not working... what am I doing wrong?
Thanks!View attachment 142898
Thanks a lot! If I ever get my hands on a multimeter that has more sensibility, I will try to measure with my hands dry! =)Your meter is set to measure a low resistance with its 200 ohms range. That is the maximum resistance on that range. But your skin is much higher. Holding my probes like you do I measure 31 million ohms when my hand is dry. Your meter can measure resistance no higher than 2 million (2000k) ohms.
In russian it is with V, Polish write it wodka.As to the guy who said one of the only Russian words he knows is "vodka", didnt you mean "wodka"![]()
Make mine a double.In russian it is with V, Polish write it wodka.
Thanks! It really helped! =)set it to its highest range (2000K).
I will surely do! Thanks!If want to contact me privately, use the (email address removed)
Right in the spot! Thanks!RE:""That's also one of the things that is measured in the polygraph test, isn't it?""
YES.
And here I am complaining about a rainy weather... Life can be scary!Then russian kgb was jabbing him into rat filled cell, and half slept pushed into highlight ray, forced electrodes
I guess the people that work with it has the right spots to measure, standard devices and tables to compare findings... but again, I really dont understand it, I'm just curious! =)I am finding this "skin resistance" measurement hard to believe using only two contact points.
No, they don't. They are guessing, just like you.I guess the people that work with it has the right spots to measure,
There are no such standards.standard devices and tables to compare findings
I do.I really dont understand it,
Hi,In russian it is with V, Polish write it wodka.
Hi,I guess the people that work with it has the right spots to measure, standard devices and tables to compare findings... but again, I really dont understand it, I'm just curious! =)
Hahahahahahaha! I LOLed! =)No, they don't. They are guessing, just like you.
I do.
ak
So do I! =)parameters that are very hard to control makes me skeptical right off from the start. I am always willing to listen to supporting arguments though.
Hi,You guy need to use the right search terms. This https://www.mn.uio.no/fysikk/english/research/projects/bioimpedance/publications/papers/SG_83a.pdf paper has a lot to say.
The term I used was "4 terminal measurement of skin impedance". OK, why did I use that term? Familiar with the term "sheet resistance" which uses 4 probes. They eliminate the contact resistance of the probes. One method uses 4 probes in line with a specific spacing. Current flows on the outer contacts and and voltage is measured on the inner ones with a meter with an input impedance much greater than what your measuring. See: http://four-point-probes.com/four-point-probe-manual/
Another technique required 4 probes, two being voltage and two being current as before, but arbitrarily placed, usually at the edge of a thin fim.
Two reading or better yet, two sweeps, are taken and then the probes rotated. A function is then applied to get sheet resistance, See https://en.wikipedia.org/wiki/Van_der_Pauw_method
In both cases, you need thickness to get the actual resistance.
I worked in the semiconductor industry.
