Its the last Schematic that you sent me that included leds on the output of the 4017. I would like either NPN or PNP transistor switches on the outputs, to drive 3 leds on each output. It can be on a separate sheet that only includes the outputs of the 4017, and all the additional info, it doesnt need to all be on the same sheet.Do you mean the schematic in post #77 ?
What do you mean with transistors driving the outputs?
To complete fully I need your schematic of the 555 driver as well.
They are blue leds so whatever is best for them, and leave the rest of the circuit as it was before. The 3 leds can be series or parallel, whichever is best for a little switching transistor.Are the LEDs in series and what value current limiting resistor?
What about your 555 driver circuit, want me to add that in as well or leave it as shown before?
C1 is electrolytic. C2 can be either.my other question is about c1 and C2.. are they both electrolytics??
I shall, but I am removing the suggested componentsTo verify that the 4017 is counting or not, connect a jumper temporarily from the collector of Q1 to ground.
Increase the value of R2.Q3 to Q12, how do I turn them on a bit longer than the time I have now?
Thank you
Kim
can you breadboard, and test please?Here's an alternate circuit.
It used two CD4017's, one as a logic state sequencer, and one as an LED sequencer.
This works using LTspice simulation but hasn't been bread boarded.
U2 controls the logic state of the circuit per the spec given by the TS.
The LEDs are limited to ~10mA. Q4 keeps GRN0 LED off when U1 is reset.
If the TS is interested, I will breadboard and test.
Edit: Removed Q4 because its not needed (forgot about Q3). Removed reset U1
sHould the 4017 be constantly grounded??Here is a re-work based of recent posts. As before, U2A and U2B form a 5-second monostable.
U2C is the most simple CMOS oscillator. It can be replaced by some other clock circuit.
The oscillator is not gated by the monostable because this circuit uses the clock enable circuit inside the 4017 to manage when the chip does and does not count.
When the button is pressed, the 4017 stops counting and whatever output is high is illuminated for 5 seconds. Then that LED goes off and the 4017 resumes counting.
As shown, the oscillator frequency is around 800 Hz to assure randomness in the display. Of course, a 4093 can run way faster than that.
ak
| Thread starter | Similar threads | Forum | Replies | Date |
| E | 4017 Frustration | Digital Design | 111 | |
| D | HELP WITH 4017 RESET | General Electronics Chat | 29 | |
| O | Using 2 decade counters CD74HC4017 to make it count 20 | Homework Help | 16 | |
Improvement for digital lock project using IC4017 | Homework Help | 15 | |
| K | Decoder encoder using 4017 with IR LED For transmitter | General Electronics Chat | 14 |
