Correct, because tf (or sys in the original syntax) must be expressed in polynomial form, hence the only data-type it can accept is type int (as far as I can see both signed/unsigned and variable-bit).Does anyone know know to use the function, [num,den]=tfdata(sys)? My transfer function(tf) is a double(complex). When I type [num,den]=tfdata(tf), it states that the function 'tfdata' is not defined for values of class 'double'.
Thank you.
H = tf([1 2],[3 0 4]); % H = (s + 2)/(3s^2 + 4)
[num,den] = tfdata(H)
num =
1 2
den =
3 0 4
