Using INCLUDES, FUNCTIONS PROCEDURES and SUBROUTINES in Oshonsoft
camerart
Joined Feb 25, 2013
3,853
hi,
Post a sample of the Function call + args
and the Function itself.
I will edit it.
E
Hi E,
I got mixed up copying and pasting the correct sections into the CODE area, so I've posted the whole program, while I have another attempt.
As it's a fairly short program, which may be acceptable, but let me know if I should carry on copying and pasting as requested.
FUNCTION at the bottom!
C
ericgibbs
Joined Jan 29, 2010
21,577
hi,
You where asking about CS select in Functions calls, procedures.
Just post a clip of a Function and its Calling args.
E
EDIT: If [ chip_sel = altmtr_cs ] is a ligitimate statement, then I could write a PROCEDURE to select [ chip_sel = altmtr_cs or chip_sel = cmpss_cs or chip_sel = 4431_cs ] and select each as the sequence procedes, and use chip_sel as one of the AGRs. Does this seem ok?
camerart
Joined Feb 25, 2013
3,853
hi,
E
Hi E,
Yes CS is the question! Each one has a different PIC PIN.
Here is hopefully all you asked for. Watch out for errors.
C
ericgibbs
Joined Jan 29, 2010
21,577
hi C,
Your understanding of the Function is way off track.:)
Note: these HEX values are for explaining the Function, use the actual HEX addr
periph_wr( 0x74 As Byte, 0x5f As Byte, altmtr_cs As Byte) ' you must the actual addr for altmtr_cs
Function periph_wr(arg1 As Byte, arg2 As Byte, arg3 As Byte) As Byte ' nothing returned
altmtr_cs = 0
chip_sel = 0
WaitUs 1
SSPBUF =arg1 ' write addr
While Not SSPSTAT.BF
Wend
WaitUs 1
SSPBUF = arg2 'wr_byte
Wend
altmtr_cs = 1
End Function
camerart
Joined Feb 25, 2013
3,853
hi C,
altmtr_cs = 0
chip_sel = 0
WaitUs 1
Wend
WaitUs 1
Wend
altmtr_cs = 1
End Function
Hi E,
Yes, early days in my understanding of FUNCTIONS/PROCEDURES
In your FUNCTION eaxample #67 there is [altmtr_cs = 0] I also want to use the same FUNCTION for e,g, [ compass_cs ] plus others, my question is how can it be used for more than 1 [ -CS ]
C
ericgibbs
Joined Jan 29, 2010
21,577
hi,
Give a sample of the actual value of a CS, say for the compass,, which pin of the PIC is the CD output.
E
For this example post the addr of the compass
camerart
Joined Feb 25, 2013
3,853
hi,
E
Hi E,
The example I posted #66 second paragraph down, is where both the [ _CS ] are set (SYMBOLS)
C.
ericgibbs
Joined Jan 29, 2010
21,577
hi,
I will look it over later.
I am running some tests on this Function command, the results I get are not consistent.?
E
camerart
Joined Feb 25, 2013
3,853
hi,
E
Hi E,
Ok, thanks.
The READings in Chip sel #71 use LIVE peripherals, which need each of the CS to be selected. How are you able to run tests?
C.
ericgibbs
Joined Jan 29, 2010
21,577
hi,
I am just dealing with basic code.
Usually a Function Returns a data value to the calling routine and a Proc does not Return any data.
In OSH it appears to be the wrong way around!
A Func does not return but a Proc does, yet the coding is shown as
Code line:
Function writeit(arg1 As Byte, arg2 As Byte, arg3 As Byte) As Word which indicates a WORD is returned.
Code line:
Proc proctest(arg1 As Byte, arg2 As Byte) ' no reference is given for the returned value!
Run this simple demo program to show this problem, I am not surprised you are having difficulty in getting the code right.
E
jjw
Joined Dec 24, 2013
823
You don't need a separate variable chip_sel.
Chip select can be done outside of the functions.
Also the values of the arguments can be written directly to the function.
For example:
wr_adr = 0x60 'WRITE 0xE0 %01100000 RESET ADDR [Is this needed?]
wr_byte = 0xb6 '%10110110 resets BMP280 = 0x00
Call periph_wr(wr_adr, wr_byte)
rd_adr = 0xd0 'address of ID =0x58 =88
rd_Byte = 0 'Dummy BYTE
data = periph_rd(rd_adr)
altmtr_cs=0
Call periph_wr(0x60,0xb6)
Waitms 50
data = periph_rd(0xe0)
altmtr_cs=1
Hserout "READ RST 0 ", #data, Cr
etc....
camerart
Joined Feb 25, 2013
3,853
Hi E,
I
ve found errors in the
hi,
Code line:
Code line:
E
Hi E,
In the full program there is a FUNCTION that return the result of a calculation.
It took me a long time to get FUNCTIONS and PROCESSES to work, and tried both in different sections, using a digital analyser to test the BITs, connected to the peripheral.
This problem only occured when I added the second peripheral.
I tried running your test in the simulator, but it stalls at [Hserout "Inside Square Function b = ", #b, CrLf]
C.
camerart
Joined Feb 25, 2013
3,853
For example:
altmtr_cs=0
Waitms 50
altmtr_cs=1
etc....
Hi J,
You don't need a separate variable chip_sel. I'll need to read this a few times, but initially, so my first comment:
Do this section:
_________________________________________________________
altmtr_cs=0
Waitms 50
altmtr_cs=1
'________________________________________________________
get repeated by this?:
'_________________________________________________________
compss_cs=0
Waitms 50
compss_cs=1
If so, then I was trying to get both in one FUNCTION.
C
ericgibbs
Joined Jan 29, 2010
21,577
hi,
This is what J is pointing out.
Code:
loop:  ''' NOTE this a READ function
Select perf1
read_any_perf(addr0, addr1)  'say comp addr
deselect perf1
'do whatever
Select perf2
read_any_perf(addr0, addr1)  'say baro addr
deselect perf2
'do whatever
Select perf3
read_any_perf(addr0, addr1) 'say some other perf
deselect perf3
'do whatever
End
'note this a Read Function
Function Read_any_perf(arg1 As Byte, arg2 As Byte) As Byte
'say read the SPI data for example
End Function
sagor
Joined Mar 10, 2019
1,055
A function has to have its name equated to the final value. ie:
Code:
Function square(arg1 As Word) As Word
b = arg1 * arg1
square = b
End Function
Will return the value 81 in the main routine. It is the name "square" that is the variable returned... SQUARE is a variable....
Always check the variable storage locations, you will also see which variables are global and which are local to the routine.
