Using DC voltmeter to measure RMS AC voltage
Status
Not open for further replies.
Shamoooot
Joined Apr 3, 2023
65
Hello
I have a DC voltmeter and I would like to design a simple circuit to that can allow measuring the RMS AC voltage on the same meter.
I was wondering if using a bridge rectifier is good practice or does it have any drawbacks?
The voltage range is 0-20Vrms, so:
Vmax = Vrms/0.707
Vmax = 28.288V
Vdc = 0.637Vmax - 2Vdiode
Vdc = 16.6
Is there a way to compensate for the drop of voltage?
Sensacell
Joined Jun 19, 2012
3,789
1) Your circuit is a peak detector, you can divide the voltage output down to the RMS equivalent, but it will only be accurate for pure SINE wave signals
2) At lower voltages, the diode drops will make the circuit very inaccurate, use an opamp precision rectifier instead of simple diodes. This trick however will fail at higher frequencies.
What kind of signals are you wanting to measure?
Shamoooot
Joined Apr 3, 2023
65
Thank you for the good info..
The signal is Sinewave and the frequency is up to 1kHz.
For precision rectifier can you suggest me an amplifier that can handle the 20V/28Vmax. I have 15V and -15V power available.
Sensacell
Joined Jun 19, 2012
3,789
Perhaps divide the incoming voltage down to +- 10 Volts first, then you can use garden variety opamps to do the rectification.
Or better yet- use an integrated solution like the AD736
Shamoooot
Joined Apr 3, 2023
65
Thank you again.
I would like to ask if the Vdc resulted from the precision rectifier would be the exact same as Vrms, and is it ok if the DC output was pulsating or does it need smoothing .
Perhaps I will go with an opamp like AD822, with summing the -15 and 15 sources to get 30 supply should be good.
datasheet
With a circuit like the one here:
design procedure
38,910
No.
The precision rectifier generates the average value of the signal.
You increase that by a gain of 0.707/0.637 = 1.1099 to get the RMS value of a pure sinewave.
For the true RMS value of of a distorted sinewave or any other signal (square-wave, triangle-wave, etc.) you need a true RMS converter as suggested by Pyrex.
Sensacell
Joined Jun 19, 2012
3,789
No.
Why not peak detect and divide by 1.414?
Shamoooot
Joined Apr 3, 2023
65
I get that it's gonna be tough for digital meters, I was wondering if it is the same for analog meters or perhaps simpler.
panic mode
Joined Oct 10, 2011
5,420
sure...
add battery and potentiometer so that your meter gets sum of input and compensation voltage.
or ... do not use diodes in the bridge. use mosfets. then the voltage drop is next to nothing. be mindful of gate voltage limitations
Status
