Using an EPROM in place of a PLD?
metermannd
Joined Oct 25, 2020
472
Other than propagation delay, are there any downsides to using an EPROM instead of a programmable logic device like a GAL?
I'd think that if the circuit was running at a relatively low speed, say 1MHz, it wouldn't be an issue, right?
38,952
Speed may not be an issue but an EPROM does not do the same thing as a PLD.
An EPROM stores digital words/numbers
A PLD generates logic functions.
35,321
Long before computer graphics displays became common place I added graphics to a popular text display terminal. I needed to create logic that would clear/set/invert single bits within a byte. In other words, I needed to read a single byte from display RAM and replace it with one bit altered depending on the clear/set/invert command.
An elegant solution was created using 32Kb EPROMs.
metermannd
Joined Oct 25, 2020
472
crutschow: What I had in mind was a lookup table stored in the EPROM such that:
D0 is low when the address bus was between 0xE000 and 0xFFFF (firmware ROM chip select)
D1 is low when the address bus was between 0x2000 and 0x200F (I/O chip select)
D2 is low when the address bus was between 0x4000 and 0x400F (display driver chip select)
D3-D7 are disregarded (padded out with 0s).
AlbertHall
Joined Jun 4, 2014
12,663
An EPROM can certainly be programmed to produce (multiple) logic functions. Way back in the mists of time I was tasked to make some custom test equipment which ws an obvious application for a microprocessor but this was not allowed. So I did it with an EPROM providing the 'brain'.
[Added] https://maker.pro/custom/tutorial/how-to-use-eeproms-to-represent-logic-functions-in-circuits
DickCappels
Joined Aug 21, 2008
10,661
Please realize that your EPROM can simulate more complex logic if you latch some of the outputs with a clock and feed the latched bits back into the address pins, thus forming a state machine.
metermannd
Joined Oct 25, 2020
472
The main goal is to minimize the amount of 'glue logic' needed without having to search for a currently available part - I have a few EPROMs on hand I could just erase and reprogram.
I did look at parts like the 16V8, but those I wanted to consider all have long lead times / large MOQs which don't make sense for something that would be a one-off project.
The original design I started with does use a 74xx138, but after consolidating a number of functions into the originally under-utilized PIA (and making the corresponding changes in the firmware), I was left with a number of under-utilized glue logic parts, making that part of the circuit an ideal candidate for simplification by substitution with an EPROM or PLD.
Dick: I have seen EPROMs used like you suggest. My work used to build boards for a customer that sold equipment used for rinsing semiconductor wafers, and several of the boards used a 2516 EPROM or even a ULN2803A transistor array to provide the 'brains' of the various functions (i.e., operating safety interlocks).
drjohsmith
Joined Dec 13, 2021
1,680
I dont know where you are,
bu ti have just ahd quick look at digikey UK
and they have thousands of CPLDs in stock
i.e.
https://www.digikey.co.uk/en/products/detail/xilinx-inc/XC2C128-7CPG132C/949448
Coolrunner II, 14 thousand in stock
metermannd
Joined Oct 25, 2020
472
MrChips: That is a concern, yes, but it seems that at 1MHz, (1000nS period), propagation delay shouldn't be an issue so long as I choose wisely in regards to the specific vendor, right?
drjohnsmith: that is WAY overkill for what I need - I'm only dealing with a 64K address space and only need to generate three chip selects. :)
drjohsmith
Joined Dec 13, 2021
1,680
PROMS are great as address decoders,
slow,
Out of interest, how are you going to generate the code for the PROM ?
how are you going to program it ?
CPLD's win in that respect, as the tools allow easy coding
and they are generally in circuit programable by a cheap JTAG USB adapter.
But yes,
PROMs are great, if you can cope with the limits
A Note, I once wrote a Fortran program to convert address ranges to a PROM,
yep I'm that old.
But it does raise question of how your going to support this
if its a one off for yourself, thats not a consideration
Since the 80's , I'd just put in a CPLD,
metermannd
Joined Oct 25, 2020
472
As for generating the PROM code, I have an Excel spreadsheet I made when I was trying to get a better understanding of how partial address decoding works. It didn't take long to adapt it so I could generate the list of values I needed for each address in the EPROM.
From there, I just needed to copy the values into a text editor, convert all the carriage returns into spaces, paste the cleaned text into a hex editor, and save it as a .bin file ready to burn into an EPROM.
If it was something I'd be making on any kind of production scale, yes, a CPLD would still be the way to go.
