Using a TINY 96 GW Motor for Electric Pencil Sharpener
shortbus
Joined Sep 30, 2009
10,049
Shear: Mechanics , Geology . to become fractured along a plane as a result of forces acting parallel to the plane.
Which is what they do when cutting the wood for plywood or veneer. Shearing is the correct term, but it is what is being done both in the crank and flat sharpener. The crank or rotary just does it in a single small area that is moving as the cutters revolve, verses the whole surface that the flat blade does.
shortbus
Joined Sep 30, 2009
10,049
You need to understand that the helical cutter in the crank type sharpener, is just the same flat cutter in the box sharpener that is wrapped into a helix. The same way that a screw thread is a inclined plane wrapped into a helix.
Skew relates to the cutting action with regards to the grain of the wood. A skew chisel is a tool used with a wood lathe and again it makes a single point of contact with the material being cut, like the helical cutter in the crank sharpener.
Not trying to be difficult, though it seems like I'm becoming, but like in electronics there are things in mechanics that have their own rules and laws. And for everyone to talk about the same thing, the terms need to be used in the same way. This stuff was taught in my early days of learning to be a machinist, back in my junior year of high school.
Tonyr1084
Joined Sep 24, 2015
9,744
My thinking on the helical cutter is that it cuts across the pencil on an angle whereas the razor blade cuts across the pencil perpendicular to the grain. Semantics not withstanding, I still wonder why the TS wants to build a nuclear pencil sharpener.
shortbus
Joined Sep 30, 2009
10,049
See I thought he wanted to motor power an crank sharpener from the begining of this. Until he showed one like Max showed in post #20.
They are both doing it the same just that the helical one is doing it with a much smaller point of contact. A point of conact that is moving up and down the angle as the cutter rotates.
Tonyr1084
Joined Sep 24, 2015
9,744
My kids crayon sharpener consisted of three sharp edged plastic blades. Plastic because that was sufficient to cut through the wax. Maybe a pencil sharpener with a razor blade should (or could) have three blades. But since the single blade works well enough for many years - and ever since I was in elementary school - why reinvent the thing?
ConstructionK88
Joined Jul 25, 2018
282
Get a cheap 30cent pencil sharpener from home depot; the one that chucks into a impact driver. Get one of those geared motors and drill a hole on the chuck shaft and insert the motors output shaft then mount it into a pvc pipe? Probably need some button cell batteries to keep the length down and drill holes in the pvc for shaving's to fall out.
Sincerely,
Mytwocents
shortbus
Joined Sep 30, 2009
10,049
I don't think it will work like that cutting the wood of a pencil. The surrounding plastic and one flat blade is to keep it from chattering and breaking the lead.
28,652
The problem that I have with sharpeners as pictured is that they seem to break the lead a whole lot of times. Hence my thinking that a much higher speed spinning cutter taking much less material at each cut, would be a better choice. Sorry if some could not visualize what I was describing, or at least trying to describe.
jpanhalt
Joined Jan 18, 2008
11,087
I agree in principle. If you have ever sharpened a pencil by hand, say with a box cutter, the smaller the cut, the better the point. Of course, concrete or sand paper do well for the final touch. But, it has been a very long time since students were told to bring several #2 sharpened lead pencils to class on Tuesday.
28,652
I can recall that although it was many decades ago.
ConstructionK88
Joined Jul 25, 2018
282
I understand your thinking. Like a 60t vs a 40t saw blade. its not just the teeth but the speed as well to keep it from chipping.
