Using 240vac devices from China
kkay
Joined Mar 13, 2022
Hi Everyone. I have a question regarding Electrical standards in China versus North America. If you have a Chinese manufactured device that requires 240vac to operate, can you operate that device in North America with the 240vac derived from L1 and L2 as set out by North American standards? Thanks.
Ian0
Joined Aug 7, 2020
13,207
Often the problem with such products is the lack of insulation, not the lack of grounding, in which case you are much better off as you only have 120V to ground instead of 230V!
MaxHeadRoom
Joined Jul 18, 2013
30,766
So if their wiring diagram illustrates a hot and a neutral only, would you just connect L1 to hot, and L2 to neutral?
Yes.
I posted late last night so forgot to add that if converting a 240v equipment that uses L1 & N to L1 & L2 , the conductor that was previously the neutral should be fused and a DP disconnect used if not already.
Also technically, if retaining any white N conductors now used for L2, they should be indicated by placing RED tape at each junction point in all the conductor connection points.
Ian0
Joined Aug 7, 2020
13,207
If you are an importer Chinese manufacturers will offer you a product with certification that complies with the standards, or a cheaper version that doesn't! Your choice.
MaxHeadRoom
Joined Jul 18, 2013
30,766
Just read some of the experiences on the CNC forum to get the idea.
They usually can be brought up to code however.
Certification does not mean a lot from China!
Ian0
Joined Aug 7, 2020
13,207
I used to work as standards compliance officer, and it was part my job was to determine the authenticity of Chinese documentation.
There is an national body called CNAS which oversees the test houses (equivalent to BSI and ANSI), and it is possible to check the validity that way.
However, I did track down the addresses of one or two so-called test houses to Chinese restaurants in east London.
kkay
Joined Mar 13, 2022
Looking at a couple specific examples. An E27 led bulb, rated at 220vac; A ceiling fan rated at 220vac. Can they be run in North America?
MaxHeadRoom
Joined Jul 18, 2013
30,766
There should be no problem running on 240vac 60hz. Usually the allowed tolerance is 10%.
If the fan is a type of induction motor, it will run a little faster.
38,634
Should be OK as long as running on 60Hz instead of the designed 50Hz doesn't significantly affect the operation of the device.
kkay
Joined Mar 13, 2022
Ok. So just connect L1 and L2 to the bulb, or to the hot and neutral wire on the fan?
MaxHeadRoom
Joined Jul 18, 2013
30,766
Yes, the 240v L1 & L2 replaces the L1 & N.
Typically it is best/safest to provide switching of both L1 & L2 rather than just the L1 that the original may have.
But in small trivial devices you just have to be aware of it.
Check for proper earth GND conductor.
bigkim100@
Joined Oct 25, 2022
last item that I bought straight from China that ran on ac had a cord that was thinner than my Earphones cable. Its cheap, but who will pay for your house/apartment/car when it burns to the ground, it wont be your insurance company when they find the smouldering remains of whatever you have there.
Ian0
Joined Aug 7, 2020
13,207
In Europe, whoever "Placed it on the European market" - if you imported it directly from China, then that's you. If you imported it, you have a responsibility to test that it meets European standards. If you bought it from a European supplier then it's the European supplier.
The problem arises when it's a Chinese supplier masquerading as a European supplier, with a European based website and an address within Europe.
Janis59
Joined Aug 21, 2017
1,893
Simply if one uses the China PS he ought to never wear the wet shoes or touch the water-tap while keeping the PS. :) :)
For those who whole life lived on 110 V - the electrocuting from 220 V only in some <1% cases ends with the real death. Most cases it ends with a minor panic attack and nothing more serious. I take even 600 V in my youth and am an example that even such is not obligatory lethal - however the muscle reaction was to push that defective vacuum gauge type PS weighting about 60 kg far far away, to the neighborous room. :)
Audioguru again
Joined Oct 21, 2019
6,826
Chinese Standards?
The electrical utility company in my large city gave away for free, compact fluorescent light bulbs so that people would replace wasteful incandescent light bulbs. The free bulbs were made in China and some dripped flaming plastic so they were all replaced.
The discovered that they were never tested for certification because their certification label was a fake copy of a real one from a competitor.
All the streetlights in my city are Chinese LED type and are on all day and all night because the system that turns them off does not work. Each light has a little modem antenna on top.
