Use of ac to extend switch life.
sternpirate
Joined Dec 10, 2015
25
You say AC, but how does the switch see this AC if it has no reference to zero volts? You could supply a 2v sine wave sitting on a 5v DC level and the switch won't know any different. The theory you refer to doesn't really work at low voltages, it's a more "high voltage" thing, in all likelihood the issue you mention would be easily solved by dripping in some contact cleaner.
What tends to happen with these microswitches, is they get dirty, then the user presses harder and harder trying to get it to work and eventually breaks the switch.
My existing code uses a software sr latch with each +click -click state bound to its specific switch contact. I assume that when the ac goes high the microcontroller would change the state appropriately. That is why I made the thread, to ask about appropriate frequencies of operation. circuit breakers work fine on this principle at 50hz but the response time would be a bit low.
1000hz would be fast enough, except it could be audible. it would be neat if the ac would be +-5v but since the power cord lacks that say 2.5v +- 2v could do.
The other posters have dissuaded me though as ac would not break through the oxides as easily, so the idea could be doomed from the start.
