http://www.allaboutcircuits.com/technical-articles-preview/36790
Hi John,
Overall it's a very solid article. Here are a few issues for your consideration:
1. Re: inductor vs. ferrite bead
This is my main concern as far as the technical information. The preferred component for IC power-supply filtering is a ferrite bead rather than an inductor. The distinction is important because beads actually dissipate high-frequency energy, whereas inductors simply store it. (You are probably familiar with this issue, but if not you might find this article interesting.) I get the impression that many designers are somewhat loose about using beads vs. inductors, and perhaps this looseness is reflected in the use of L as a reference designator prefix for both types of components (I always use FB for beads). I, on the hand, am very weary of inductors in power lines; I don't like the idea of all that inductance and capacitance sloshing energy back and forth and perhaps causing unexpected ringing.
Anyways, I noticed that in the BOM you identified L1, L2, and L3 as beads, but throughout the article you use the word "inductor" and you mention an "LC" filter (instead of an FBC filter, as I call it).
What are your thoughts?
2. Re: speed vs. throughput in the table
I noticed that the speed for BLE is significantly higher than for classic, but BLE's throughput is much lower. Does that seem right to you? Does BLE have a bunch of extra overhead that slows down the actual rate of data transfer?
3. "BLE is designed primarily for applications requiring simple data (such as sensor data) rather than complex data or streaming audio."
I'm not clear on the distinction between simple data and complex data. In the end it's all ones and zeros. Perhaps you're trying to say that BLE is designed for devices that require only intermittent transmissions of relatively small packets of data.
4. "The use of a module will simplify the design and drastically reduce certification costs—but it will also increase the production cost."
A while ago I was pricing out some IoT concepts for my brother, and I came away thinking that it would be very difficult to significantly reduce BOM cost by using a custom design instead of a module. Have you found that a good designer really can beat the modules when all BOM and assembly costs are factored in?
5. "Inductors L2, L3, and L4 provide some power supply isolation"
I think this should be L1, L2, and L3.
6. "Power and ground planes in the PCB should not run under the device, because they could provide an unwanted thermal path to the sensor."
This issue is a bit confusing, and I'm not sure what to do with it. The datasheet for the MPU-9150 is very clear on two points: the exposed pad should not be soldered to the board, and no traces or vias should be placed under the exposed pad. But with power and ground planes, the situation is not so clear: "Note: For best performance, design a ground plane under the e-pad to reduce PCB signal noise from the board on which the gyro device is mounted."
Also, I think that the thermal path is only part of the story, and saying it this way gives the impression that the copper won't be problematic if there is not significant heat being transferred to the MPU-9250. Part of the problem, and perhaps the more significant part, is that copper somehow interferes with the MEMS stuff (at least the gyro, maybe the magnetometer as well): "Routing traces or vias under the gyro package such that they run under the exposed die pad is prohibited. Routed active signals may harmonically couple with the gyro MEMS devices, compromising gyro response."
7. "An antenna will normally require the use of a pi-network for tuning the antenna (i.e., altering the impedance of the antenna so that it is more compatible with the transceiver's input and output circuitry)"
This is my revision, which was intended to make this sentence a little more clear and informative. Does this look OK to you?
8. Re: Bluetooth Smart
Is Bluetooth Smart the same thing as Bluetooth LE? If so, we should probably mention that somewhere in the article. It will be helpful for readers and good for SEO.
Hi John,
