Unknown component
Status
Not open for further replies.
Gogeta2000
Joined Aug 23, 2014
1
Hi! I have a problem with this chip.
It's a disposable external chip of a uv lamp.
Philips uses this chip as a pay-per-use key.
The expensive lamp is mine, but i have to buy this chips to use it!
Every chip allow me to use the lamp for 4 cycles of 15minutes.
I would like to use the lamp without limits.
Have you got any suggestions?
Thanks
Ps: on the black component i can read: 2D+ 1002 317B2
THE_RB
Joined Feb 11, 2008
5,438
It is likely to be a microcontroller.
Can you show the PCB of the lamp itself? It will be much much easier to "hack" the lamp electronics directly.
And what product is it where they try to force you to only use it 4 times before buying another? Did you agree to any sort of contract? :eek:
bertus
Joined Apr 5, 2008
22,926
We will not allow you to break a copyright.
This is written in the ToS:
Please do not make requests for, or post links to, material that otherwise contravenes the conditions of the original or subsequent author's copyright. All instances of such requests will be met firstly with a warning, and secondly with a ban.
Consider this as your first warning.
Status
