Unexpected behavior from vintage 7-SEG display
ApacheKid
Joined Jan 12, 2015
1,762
I found a big bag of old 7-SEG display, turns out these are FND-503 type, common anode (originally manufactured by Fairchild I think).
Anyway I was playing with some of these (they are surplus I bought many years ago and promptly forgot about) and found that at 1.6V they begin to faintly glow with around 16mA flowing, then at 1.7V they go brighter and consume 48mA, but then as I increase the voltage further the current is rock steady at 48mA and the brightness shows no perceptible change.
A forward biased diode would be expected to obey ohms law-ish once its started to conduct, so what gives?
(Also no datasheet can be found, I was able to deduce connections from experiments and there are datasheets for FND-500 etc which are likely close)
ApacheKid
Joined Jan 12, 2015
1,762
How did you connect the display to power?
Are you using individual resistors on the segment pins?
All eight pins (seven segments and dot) are connected to -Ve and the anode to +Ve and I have a precision multimeter measuring the DC current as I manually increase the applied voltage (which has 0.01 V granularity), so this is effectively eight LEDs in parallel.
dl324
Joined Mar 30, 2015
18,454
Old LEDs, and many new ones that aren't high power, are spec'ed to operate at a maximum continuous current of about 20mA. They can operate at higher currents when pulsed.
Note that even though forward voltage is specified at 60mA, the maximum continuous or average current is 20mA:
The IV characteristic you observed is somewhat expected:
Brightness isn't linear with current and the human eye is logarithmic, so you can't differentiate a brightness change of less than about a factor of 2.
ApacheKid
Joined Jan 12, 2015
1,762
Yes I understand that, what puzzles me is the contancy of the current as voltage is increased to 2, 3, 4 and more volts, like the current is rock steady at just over 48mA.
35,122
This has been stated repeatedly. Don't do what you are doing.
Put a 470Ω resistor in series with the LED otherwise you are at risk of burning out the LED.
ApacheKid
Joined Jan 12, 2015
1,762
Hi, let me explain, I don't care if the device gets damaged, I have forty of them in a junk box. I am simply experimenting. I will add a resistor though as it will help make these adjustments more smoothly.
ApacheKid
Joined Jan 12, 2015
1,762
Only had 390 Ohm, but anyway, at around 10V now the device glows weakly and pulls around 20 mA, as I adjust voltage the current varies, but does eventually reach 43mA again and never rises thereafter.
ApacheKid
Joined Jan 12, 2015
1,762
ApacheKid
Joined Jan 12, 2015
1,762
Hi A,
An LED is a Diode, and diodes do NOT follow Ohms Law.
E
I know, that's why I wrote "obey ohms law-ish once its started to conduct" because once conduction reaches a certain point we expect the current to rise rapidly for small increases in voltage.
This is what puzzles me, what am I failing to take into account here?
sghioto
Joined Dec 31, 2017
8,750
the FND500) is designed to pass no more than 25mA continuously give or take.
That's the max current per segment. The specs say low current requirement of only 5 ma per segment.
In your setup you are showing 25 ma for the entire display. Divide by 8 and its only 3 ma per segment
ericgibbs
Joined Jan 29, 2010
21,562
hi A,
They do not even obey Ohms Law-ishly .
Forget the Ohms Law and focus on the published V/I curves for your particular LED.
E
ApacheKid
Joined Jan 12, 2015
1,762
hi A,
E
Look at the example chart I included above, between 1V and 4V the line is approx straight, that is consistent with Ohms law Eric.
ApacheKid
Joined Jan 12, 2015
1,762
Yes, you're right, I was hasty it is 25mA per-segment! I just adjusted everything again and increased the current limit.
OK 1.78V causes almost exactly 200mA and it looks like I'd expect it to look, pretty bright but not as bright as today's efficient one.
Thanks, this was all due to me being a bozo!
