undertstanding questions
braddy
Joined Dec 29, 2004
83
Hi I have two questions I need help with.
1- I am asked to design a experiment to determine the capacitance of of unmarked capaictor. I suggested the time constant method but I was told to indicate another one. Can someone see something else?
2-The other questions are for my understanding of the oscilloscope probe :
-I would like to know why high frequency cause problems to the probe of an oscilloscope?
-If I am not calibrating a probe and I make measurements, I introduce errors in the AC component not in the DC component because of the probe capacitor, right? Can I have a brief explanation about what is going on?
Thank you
B.
Johann
Joined Nov 27, 2006
190
Thank you
B.
Point 1. Connect capacitor to an ac source of known frequency and voltage (AC) with current meter in series. Measure voltage applied and current flowing and by applying Ohm's Law, you will have the capacitive reactance, Xc. Now apply and manipulate the formula, Xc=1/(2 x pi x F xC) to determine the value of C. (I'm sure you're familiar with this?).
Point 2. Exactly because the probe consists of 2 conductors running close to one another inside the probe cable and will have a certain value of capacitance. Apply the same formula and see for yourself how the capacitive reactance behaves with increased frequency!:)
kubeek
Joined Sep 20, 2005
5,795
Point 1. You can use a constant current source and measure voltage on the cap after being charged for defined time.
hgmjr
Joined Jan 28, 2005
9,027
This suggestion it more along the lines of a slightly crude implemention of kubeek's excellent constant current scheme for addressing point 1.
The suggestion involves taking a 555 timer chip and setting it up so that the capacitor to be measured can be connected into the timing section. The capacitance could then be calculated be using the formula for frequency of a 555 timer as a function of the capacitance in the timing circuit.
Measure the frequency then plug the value into the formula and compute the value of capacitance it would take to produce the measure frequency.
hgmjr
John Luciani
Joined Apr 3, 2007
475
1. As was suggested I would use the constant current source. If you have
an oscilloscope it is easy to implement.
2. All of the high frequency problems with probes (that I have seen) are due to
uncalibrated probes, mismatched probe/scope and noise coupled to the ground wire
of the probe. Verify your probe impedance matches that oscilloscope and
calibrate your probe. The scope manufacturer provides a table that lists the
proper probes for your scope. Noise coupled to the ground wire is due to the area
of the loop formed between the ground wire and the tip. This acts as an
antenna. See my notes and pictures at
http://www.luciani.org/eng-notes/ee-notes/ee-notes-index.html
(* jcl *)
