The guitar input i'm connecting is coming from my Zoom G3x Guitar effects processor. I just want it to be linear, nothing fancy..Hi,
Unless your guitars have on-board or inline pre's or other form of impedance conversion (before your mixer), you shouldn't worry over sound quality, as there'll be nothing but The Sound of Silence (+noise)
For a clean guitar pickup (i.e. just the wire), you need around 1M Ohm of input impedance (and good cable) for clean highs - 5k Ohm will quench even the lowest notes.
Yeah, it's nice! And it's got ZOOM written all over its displaysThe guitar input i'm connecting is coming from my Zoom G3x Guitar effects processor. I just want it to be linear, nothing fancy..
Here's the link of the processors specs ... http://www.zoom.co
.jp/products/g3/spec/
5k won't quite cut it, if you go for the best result.(Output load impedance 10kΩ or higher)
Well Soren, when ever we(me and other guitarists) get together to jam, we are limited with only one amplifier, so each has to take turns . Sometimes, the playing tends to be so well that we get greedy and not give others a chance . To avoid this i am building this circuit so that all of us can connect and play to a single amp (taking turns of course).I don't quite understand your wish to go from a ZOOM to a crude mixer and into whatever though (the word sacrilege enters my brain )
Could you suggest me some good low noise opamps, bjts and fets for audio applications?If you need help with component values, just shout.
Taking turns? Where's the jam in that?Well Soren, when ever we(me and other guitarists) get together to jam, we are limited with only one amplifier, so each has to take turns . Sometimes, the playing tends to be so well that we get greedy and not give others a chance . To avoid this i am building this circuit so that all of us can connect and play to a single amp (taking turns of course).
The noise part is the only possible reason to avoid the LM358 (40 nV/√Hz) IMO, but I'd still try it out. With a good quality (turned pin/tulip) socket, you can upgrade to whatever later, if you don't find the LM358 adequate and it's the cheapest way to go. If you put a noise gate between mixer and amp anyway, you'll never hear the noise, as it will be completely drowned when there's a signal.Could you suggest me some good low noise opamps, bjts and fets for audio applications?
Well i ment to say taking turns to play solos...
Guitar electronics is quite another beast than general audio and I'll never understand the craving for the extreme, just to hit it with waahs, flangers, phasers, fuzz and what not - if you can't hear the noise, then trying to remove it, is a colossal waste of time, pure and simple.
BJTs and FETs are sort of out of place in a thread about an op-amp mixer, so I'll skip that part, but for the project you outlined, any dual op-amp (with a few exceptions) will have the same pin-out, so you can try out most, just by swapping.
Classic offers would be: TL082 (25 nV/√Hz), TL072 (18 nV/√Hz), NE5532 (5 nV/√Hz) , OP27A or -E (3 nV/√Hz) and you can get below (1 nV/√Hz), but you won't get a better sound that way and as the noise go down, the price goes up.
I Attached a file with a schematic of a working mixer. Depending on input amplitudes, you can get THD under 0.001%, way better than needed. Should you find it noisy, just hit it with an OP27A or similar.
GreatGuys i built the practical circuit little different than what Soren has given... i used 10k and 10uf cap instead of 100k and 1uf, when i used lm358 it sounded crappy, there was no linearity i replaced it with tl072, sounds kickass... M very pleased with the result, Thank you all once again
Yes Soren, I refer to distortion. I had connected my guitar directly into the device, and without even cranking up the gain i was getting overdrive like effect, but now itz resolved, thanks to tl072.Great
What exactly do you mean by "linearity"?
Are you referring to distortion?
(Too high an input amplitude would increase distortion to some degree).
The reason for 1µF/100k was simply that a non-polarized 1µF cap is relatively easy to come by and (even without selling your soul to the downstairs guy), while 10µF caps are rare and expensive - you didn't use polarized caps (electrolytics) I hope?
OK, good to know - there's a lot of difference in output voltage levels from different pickups, so that might be the reason.Yes Soren, I refer to distortion. I had connected my guitar directly into the device, and without even cranking up the gain i was getting overdrive like effect, but now itz resolved, thanks to tl072.
I can't find anywhere Dick Cappels endorses the use of polarized caps in the input?I've used the Polarized capacitor following Dick's advice in Page 1. Why should/should'nt use a Polarized cap?
@Soren.. Thank you for your reply, as of now i'll just let it be as it is, will plan on changing when sound degrades. And here is Dick Cappels post.You also need some other capacitors in your circuit.
Put a capacitor in series with each audio input resistor with the negative end connected to the pot wiper.
Oh that post, yes, thanks.@Soren.. Thank you for your reply, as of now i'll just let it be as it is, will plan on changing when sound degrades. And here is Dick Cappels post.
Compared to their size, they have huge capacitance and while they're no good when frequency depends on them, they have oodles of other uses - eg. anytime you need to store energy or decouple supply lines (where you'll typically gang them up with ceramic caps for high frequency handling). Rest assured, if they had no particular purpose, they'd vanish like eg. the E-cell did.I've heard/read many people telling that electrolytic cap is unrelaiable in long run.... I begin to wonder if they are so unrelaiable what are their uses then, why are they still being manufactured then??!!
by Robert Keim
by Aaron Carman
by Jake Hertz
by Jeff Child
