Back in the 60's I installed some off-peak storage heaters in a residence, this is where the service company required the 3phase for them.That's great thank you.
I don't see that happening. My home, an older home was originally setup with 60 Amp service. Matter of fact all knob and tube wiring. Over the years as we ripped out and replaced walls and ceilings over two floors I removed it all and also installed a 200 Amp service panel. Then the conduit riser to the weather head cannot exceed 40% fill with the conductors and the weather head must be capable of supporting three #2 AWG copper or three #1/0 aluminum or copper clad aluminum conductors. Here in the US the weather head is the customer responsibility. Next you need a meter enclosure for a meter which supports the service, the the enclosure is also customer responsibility. The service provider provides only the meter which is also rated for the service.My answer to your question would be you can hook as many things in your box as you want as long as you have room in it. Ample breakers on the circuits, a big enough backyard and the guts to tackle 1000 GPM coming at you. "The video" I watched about 10 minutes of it and he has some good pointers.
Brzrkr
Yes the UK distribution is via a 3ph transformer and a star neutral, with every so many residences on one phase.That's pretty cool in that in the UK you can likely get 3 phase service easier than in the US which if running a few 5 HP pumps would be a big plus. Here in the US getting three phase service is not all that easy for a home residence.
Ron
Actually I happen to have a few three phase lines on my street. Same deal as every so many houses a transformer off a different phase. I am guessing since I really don't know but the lower 3 phase is 7 KV and the higher lines. Looking at the insulators, I put at 25 KV. The problem comes in when getting it to a residence because they need to add a transformer (or three transformers) to drop all three phases for a single residence. They bill you for that. This is a bummer if the area only has one single phase high voltage feed. The lines on my street are an exception to the norm around here too.Yes the UK distribution is via a 3ph transformer and a star neutral, with every so many residences on one phase.
So it makes it a little easier to obtain 3phase.
Max.
The OP is located in UK, why mention US??Half the posts on this thread talking about 3 phase ....ridiculous !
No need for 3 Phase !!!
