Hi all,
I’m looking for a little help creating a switch for my pc mining rig, using an led from a solar battery charger,
The solar battery charger has an led that comes on once the sun is up and is charging, I want to use that led as a trigger for my mining rig to come on and only mine when the sun is up,
I was thinking of a relay that uses the 12v from the chargers led for the input, to trigger the pc’s on/off button, the only thing is, I need it to just click on for a millisecond to start the mining rig, then use the other led (that states no solar charging) to click on (again for a millisecond) for shut down, the relays ive seen stay on or off,
Any help would be great,
Thanks,
Phil.
Thanks,
Phil.
