MOSFET not fully turning off IRLML6402
adamskyyy
Joined Feb 27, 2025
7
Hi everyone,
I'm working on a project using an Arduino Pro Mini (3.3V version) and a P-MOSFET IRLML6402 to control power to a module. The MOSFET is wired as shown in the attached schematic.
Setup:
  • Arduino Pro Mini (3.3V)
  • P-MOSFET: IRLML6402
  • Control pin: D10
  • Supply voltage: 3.3V
Observed Behavior:
  • When I turn the MOSFET on (digitalWrite(pinD10, LOW):
    • Drain (D): 3.3V
    • Gate (G): 0.146V
    • Everything seems to work fine.
  • When I turn the MOSFET off (digitalWrite(pinD10, HIGH):
    • Gate (G): 3.3V
    • Drain (D): 0.3V - 0.6V (I expected 0V!)
Even though the MOSFET is supposed to be fully off, there's still some voltage left on the drain.
Questions:
  1. Why is the MOSFET not fully turning off?
  2. Could this be related to the gate-source voltage threshold (V_GS(th)) of the IRLML6402?
Would appreciate any insights! Thanks in advance.
Arduino code for mosfet:
#define pinA3 A3
#define pinD10 10
void setup() {
  pinMode(pinA3, OUTPUT);
  digitalWrite(pinA3, LOW);
  pinMode(pinD10, OUTPUT);
  digitalWrite(pinD10, HIGH);
void loop() {
  Serial.begin(115200);
  Serial.println("Mosfet turn on 5 sec...");
  digitalWrite(pinA3, HIGH);
  digitalWrite(pinD10, LOW);
  delay(5000);
  Serial.println("Mosfet turn off 5 sec...");
  delay(5000);
adamskyyy
Joined Feb 27, 2025
7
Good question! Currently, there is no load on the module. However, I have connected an SHTC3 sensor, but there is no response. On the other hand, when I connect a Quectel LC86L GPS module, it works fine.Zrzut ekranu 2025-02-27 o 20.53.59.png
sghioto
Joined Dec 31, 2017
8,750
Without a load there is sometimes a residual voltage. Try a 10K resistor from Drain to ground.
Check polarity of the SHTC3 sensor? Does it work connected directly to 3.3 volts?
