Turn on and off video of HDMI and DP cables
Paldin
Joined Dec 15, 2024
8
Hi, I want to be able to turn on and off the video (i don't mind if other stuff like audio also turns off) of HDMI and DP cables (male to female) coming out of my PC/GPU, with esp32 powered by my PC USB.
For HDMI I used pin 1 and I control it with relay that controlled by ESP32. For DisplayPort I used pin 18 that is controlled by another relay.
Currently it is working fine but I wonder if it is safe to do and if you have alternative way to do this instead of two relays.
ericgibbs
Joined Jan 29, 2010
21,654
HiPaldin,
Your method, switching a relay via a transistor, is a well-used method, no problems.
E
Paldin
Joined Dec 15, 2024
8
HiPaldin,
E
Thank you, good to know. I wonder if there is another solution I can use instead of 2 relays or relay at all. the HDMI and DisplayPort will be both on or off.
MrAl
Joined Jun 17, 2014
13,923
For the HDMI for example, you can buy an HDMI switch which allows you to either switch one HDMI source/port off or switch between two HDMI sources.
Paldin
Joined Dec 15, 2024
8
Switch is too big and I need both for HDMI and DP. I'm not sure if you suggested this instead of the esp32 but my project depends on the esp32 code.
ericgibbs
Joined Jan 29, 2010
21,654
hi Paldin,
If space is a problem, there are 2 Pole Change over type relays.
For HDMI & DP switching.
Chose the operating voltage to suit your Vin and the contact rating to suit your load.
Also, as you have shown in your diagram, a suppression diode is required across the relay coil.
E
