Thanks for the info KISS... I gotta try this 555 chip thing.. it looks like it will work.. and it does look simpler than what you suggest .. your idea may be great... But it's above my understanding.. you would have to work very hard to fill in the blanks... and it might not be worth your time .. please stand by while I try MrSalts idea... thanks much.You also might be able to pull it off with an LT6700 It comes in 3 different varietes. https://www.analog.com/media/en/technical-documentation/data-sheets/6700123fh.pdf One does both polarities. There is also a one comparitor version of the chip.
You need a resistor to drop some voltage. Lets use 400 mV. So, you need to say if it;s less than 400 mV turn it on. Turning it on will make it >400 mV, so it turns off. There might be a problem as to how long you have to press the button.
So, you would put some resistor that drops >400mV in series with the power negative. or maybe power positive,. Look at the datasheet.
400 mV is the minimum you can set using this part.
You MIGHT need to extend the pulse,
tThe idea is pretty simple,but it depends on how long you have to push the button. If you have to push it for 1s, then no it wo;t work. If it uses the edge, then likely it would work
And it's two parts, maybe 3.
A bypass cap (0.1 ceramic)
The LT part. It's open drain. Just what you need.
400 mV is fixed. Probably not a problem.
It would depend on a fixed power supply somewhat.
You need a resistor that drops > 400 mV when the LED is on. R=0.4/15mA = 26 ohms.; check wattage.
Advantage: no big parts.
Say an external 3.6V power supply, A lithium battery would also work.
In fact, it would take about as much room as the switch.
I believe you are correct MrSalts, thank you both for thinking about this... the solution will need to be quite small in size .. there will not be a "circuit board".. everything must assemble in a "blob" like a 3D sculpture of minimum wiring, and be stuffed into the battery compartment of the sub ... it's gonna be tight! there may be a little epoxy bonding once the circuit is "formed" to fit .. no need for any insulation.. the mineral oil is almost as good as air .. might be even better ... (like transformer oil.)There is no need to denounce anything on this device. Any contact of the switch and it will activate and the switch doesn't do anything for 20-seconds (even if the user keeps the switch held in). The 555 with an NPN "switch" is the way to go here. Super simple and, most important, the OP understands the solution. It can be made with a simple protoboard - no EasyEDA needed.
KISS ... Please be a little more specific. there is yet much I don't understand about your idea. Would you please provide a circuit diagram and specific component identities.@MrSalts My idea is dependent on their debounce time, if any, inside the hallmark device.
@MFL thank you for the flick test, so likely my idea would work. There might not be any perceivable OFF time either.
You don't really want to combine both circuits, but they could be.
I gather it's not a "one of" either". It can be made smaller. Three tiny parts. Really only two. The 267 ohm resistor is in series with the GND power lead. The bypass cap is a "suggested" component.
Replacing the LED point A, and the sub to + & - .. works great!
it is simple.GADZOOKS! That's quite a reply. what happened to Keep it Simple?
The answer is probably yes. However, it does light up quickly when power is applied now.. with the button removed. The cap is 10uf, R1 is 390 ohms and R2 is 3 K ohms .. downtime is about 21 milliSec. and freq is about 23 hz .. there is a hint of a blink at each re-light.. barely noticeable. and yes.. I could run 3 wires .. but the fun part will be making the clump of a 3D sculpture out of the components to fit inside. Failing at that... I'll run 3 wires ... sigh! OR...Or instead of running just power to the sub, run three wires to the sub and have the 555 on a circuit board outside of the tank.
Last question (I should have asked first. Does the sub light up one cycle when you first apply power to it? That is, without applying power. Now that the button is removed. You can just connect A to ground and plug it in. If it does make the first cycle on its own, you could just power the sub directly with the 555 output snd ground. That is, the 555 outside of the tank and two wires to the sub.
I think it is the safest bet. I checked my notes and I used a small npn or small n-channel Mosfet when I was setting up some pop-culture museum pieces with similar on-switches.The answer is probably yes. However, it does light up quickly when power is applied now.. with the button removed. The cap is 10uf, R1 is 390 ohms and R2 is 3 K ohms .. downtime is about 21 milliSec. and freq is about 23 hz .. there is a hint of a blink at each re-light.. barely noticeable. and yes.. I could run 3 wires .. but the fun part will be making the clump of a 3D sculpture out of the components to fit inside. Failing at that... I'll run 3 wires ... sigh! OR...
If you are correct.. with "A" grounded, The sub should light when powered then cycle ground with the 555 remote... nice!
Too late.. my mind is fixed on stuffing all the parts inside and just applying power .. power which will appear faulty...PS: The NPN is doing the switching nicely.. but, you don't think it's needed?
I do like it.. Ya know... I could have just pushed the button down, added a little super-glue to keep it down, and soldered two wires to the battery terminals screwed the battery cover back on, and would have been good to go in a few minutes... sigh!I think it is the safest bet. I checked my notes and I used a small npn or small n-channel Mosfet when I was setting up some pop-culture museum pieces with similar on-switches.
KISSit is simple.
There is one thing I learned a long time ago, but it's generally rejected my management early, but it's a good technique. I did see it later described in a profession publication of the ISA (International Society of Automation).
You basically throw all of the ideas at a problem initially no matter how bad they are. Sometimes you can use pieces of the ideas.
The other idea is:
a) design the circuit as if you have infinite resources.
(tiny, reverse polarity protected)
b) What do you absolutely need.
(quick and dirty - works)
c) Add "hooks" for future enhancements.
(reverse polarity could be a future enhancement)
With software it's a different issue. You can design things so the enhancements can easily be added later without a re-write.
I kinda do a "thinking out loud" and when I did that, putting a resistor in the ground lead didn't make sense.
When iterating again, 3.3V made more sense for a power supply than 3.6V.
I've done some pretty big projects on my own. I maintained a Scanning Electron Microscope to the component level. No training at all. Someone taught me how to do laboratry glass blowing in a few weeks and I taught that skill to my replacement 6 weeks later. I sealed stuff under vacuum, attached a round quartz tube to a square quartz tube and sealed it. I made controlled leaks in a quartz tube. It helped a lot that I could silver solder/braze, solder, weld (tig, mig and stick).
Pointing a chimney (bricklaying) was fun, but I had help on the ground from a bricklayer. He mixed the mud and provides some tools and expertise. Designing a drainage system proved to be fun too. It's not 100% complete.
There are a few things:Because your reference was related to de-bouncing technology .. I didn't first "get-it" I didn't appreciate the nature of the 6700 and the regulated power supply required... more studying required... (I am not an electronics engineer ..by the way ... I just play one in my lab.)
You are right, this version (using 555 output to power the sub) would be difficult to control the flicker after each cycle vs the npn version.I do like it.. Ya know... I could have just pushed the button down, added a little super-glue to keep it down, and soldered two wires to the battery terminals screwed the battery cover back on, and would have been good to go in a few minutes... sigh!
sooooo, could you be more specific about how this would work... wouldn't You have to close the circuit and "keep it closed" for about 20 seconds, then open it and close it again for the same time. I guess one could add a pot and tune the "on time" to be only a few milliseconds longer than the lighting "on time".. but then there's that charging cap in the light control timer..?
The way it works now... the flicker of darkness at the re-start.. is barely noticeable. 555 is running about 23 hz
