Thank you...I have some 555's and will breadboard it soon... will let you know what happens.. Thanks much, Regards, MichaelOu can change the cap to get much slower. I didn't tune the frequency. 10x to 100x cap will give longer pulses and a higher value resistor (bottom resistor) will increase pulse duration.
MrSalts... your input is much appreciated.. I'm a little worried about connecting the output of the 555 chip to Point "A"Thank you...I have some 555's and will breadboard it soon... will let you know what happens.. Thanks much, Regards, Michael
Most likely, the Point A is the input to a logic chip or a microcontroller or (most likely) the trigger (pin 2) of a 555 timer. These are high input impedence and no significant current will flow out of point A to ground.MrSalts... your input is much appreciated.. I'm a little worried about connecting the output of the 555 chip to Point "A"
This is how I see what we know at this time:
The 555 chip will be applying 3-4.5 VDC to Point "A" (normally at 2.6 to 2.2 depending on if lights are off or on) many times a second... while "A" can go to ground at any time while lights are on.. can it go positive while lights are on? (above 2.2 V)?
Regards, Michael
My biggest concern is what the mineral oil will do to your plastic. Injection-moldable plastics are much more susceptible to swelling than cast resins that polymerize in the mold. Please check if your scraps from the cut-off bottom will be compatible with your mineral oil.You are awesome MrSalts .. I will make it happen.. if it works.. you get a bag-o-Lindt-chocolate trufflesPS: I think I have all the parts &
0.629 Hz ought to be fine ...
I did measure the voltage from A to B (that yellow paper where I show what we have. Post. # 30Most likely, the Point A is the input to a logic chip or a microcontroller or (most likely) the trigger (pin 2) of a 555 timer. These are high input impedence and no significant current will flow out of point A to ground.
Let's try, connect your Nautilus to your breadboard power supply. Touch a 1k Resistor across Point A and Point B to see if it triggers. If not, try a 100 ohm.
Also, measure voltage across Point A and Point B when you are powering the Nautilus from your breadboard.
I'll try that when I get home... Looks like you are thinking about not using the NPN switch?EDIT - I didn't see your image (didn't load. I have some slow wifi issues). Ok,
If you put a 100 to 1000 ohm resistor between Point A and your 555 output, we should be quite safe.
