A fellow I worked with had previously worked at a shipper. He said that packages marked "fragile" were thrown underhand.If you ship UPS, be warned, they do a 'Drop Test' on every shipment!
Max.
Max.
HP So it's lots of light, high velocity debris, fire and long term contamination? - Sotra like an H-bombMetal-halide and Na vapor lamps explode all the time! As do the execrable JVC & Sony '4K' series projection lamps!
#12 I say reliability is goodMy preference is reliability. I have found that running HPS bulbs 10% under rating results in a lifetime I can't measure yet. They have been up those 20 foot poles for 20 years and still haven't failed./
A little imagination, please. You can run any color you want with higher reliability if you run it a few percent below its rating.#12 I say reliability is good! But I just can't take that Na spectra
#12 That's really interestingA little imagination, please. You can run any color you want with higher reliability if you run it a few percent below its rating.
Agreed! If under-powering is workable for Hg-vapour 'twould be a good deal indeed considering their scarcity...It's worth experimenting with cuz bulbs are harder to find every year
Which bulbs are harder to find? What style, what wattage?It's worth experimenting with cuz bulbs are harder to find every year
Thanks to (US) 'nanny state' regulations - it seems all Hg vapour HIDs are being phased outWhich bulbs are harder to find? What style, what wattage?
Speaking for myself, it's merely personal preference -- I far prefer the comparatively 'narrow' short-wavelength Hg-Vapour spectra to that of any 'flavour' of metal halide lamp I've seen...Is there a special application you have for those bulbs in the clear design?
Over the years as the old MV bulbs go bad around here I just switch them over to Metal Halides. 200 watt MH's for the 175 MV's and 400's MH's for the old 400's MV's. 1000 watt MH is the biggest I work with here.
I can't know the answer to that. Hg and Na lamps work under the same principle...gas discharge.So does that mean I was below 90%?
Resizing your ballast capacitor does it better being many of those HID ballasts are designed to be constant wattage units which will not see an appreciable lamp wattage drop until the input voltage is reduced by 20% or more.I can't know the answer to that. Hg and Na lamps work under the same principle...gas discharge.
I can't see a problem with that. Just lower the line voltage to 108 and you should be home free.
Or at least free of replacing bulbs for many a year.
I've been working with small, cheap ballasts. 70 watts or less. A buck transformer takes my local over-voltage problem from 8.7% high to 10% low and makes a huge difference in lifespan, like 20 years instead of 3 years.many of those HID ballasts are designed to be constant wattage units
If it works for you andthe ballast yo uhave that good.I've been working with small, cheap ballasts. 70 watts or less. A buck transformer takes my local over-voltage problem from 8.7% high to 10% low and makes a huge difference in lifespan, like 20 years instead of 3 years.
Way cool, if that's your goal.![]()
Tcmtech my 175w hid ballasts don't use caps they're just autotransformer with magnetic shut for current limiting. I say there'd be more incentive for PFC if hydro charged for reactive power! I always wondered why they don'tMy #1 issue with HID lighting around here is the ballast capacitors going out.
Yea the cheap ones don't have capacitors on them. I've scrapped a few hundred in my life now.Tcmtech my 175w hid ballasts don't use caps they're just autotransformer with magnetic shut for current limiting. I say there'd be more incentive for PFC if hydro charged for reactive power! I always wondered why they don't![]()
Sir, you are mistaken. The ballasts I have are simple inductors, nothing but a coil on an iron core. Two wires. No taps, no capacitors.So say you're being cheap on bulbs like #12 and you get 20 years of run time from a 400 watt yard light that averages 12 hours a day use over that time. In proper operating mode that 400 watt bulb and ballast burns ~37,230 KWH over 20 years.
In cheap bastard mode using the input voltage reduction method to reduce the lap output he burned 39,420 KWH costing him and extra 2190 KWH of electricity worth say 8 cents a KWH average over the 20 years worth $175 in order to keep from having to change out a $100 in light bulbs plus his yard was less well lit the whole time.![]()
Saving 400$ a month was that in California, I lived there for a bit a and the power bills where crazy.If it works for you andthe ballast yo uhave that good.
The guys first thought was just how much more power that lighting conversion was going cost them due the obviously substantial improvement in light output. Surprising to all of use their monthly power bill dropped ~$400!![]()
