Absolutely understood... Thanks for the datasheet! The one I have I think is incorrect.Note that the 5% guideline for BC547 doesn't apply to all transistors. General purpose 2N transistors use 10%. The appropriate number can be found in the datasheet.
Completely understandable that you wouldn't have expertise in everything your employer did.
When I worked at HP Labs, we reported to Bill Hewlett. I doubt that he had detailed knowledge of everything the labs worked on.
The BC547B's worked like a charm - perfect brightness now! Thank you for the suggestion.Note that the 5% guideline for BC547 doesn't apply to all transistors. General purpose 2N transistors use 10%. The appropriate number can be found in the datasheet.
Well, at least it was perfect for the first 30 seconds.
It ran perfectly, then just froze with only one channel lit. So I swapped out the 547's just in case. Same thing.
I ended up swapping out ALL the components. Same thing.
I have ZERO clue as to why this is happening.
Is there something else needed connected to the 547's maybe? I am guessing no.
Without the transistors, it runs perfectly 'forever'.
I have 3 CR2032's in series powering this.
Thanks again...
Mike
I would think if the 4017 had failed, it wouldn't work at all.
