Troubleshooting an Industrial Motor Driver
Dritech
Joined Sep 21, 2011
907
Hi all,
I have a damaged Kollmorgen S200 series servo motor driver that I wish to repair. I did some search on the net, but found no schematic of the driver.
Is it possible to troubleshoot such device without a schematic if no damaged companents are visible? Any clues of what I can do to make it work?
Thanks in advance.
mcgyvr
Joined Oct 15, 2009
5,394
Well you would have to identify the sub circuits and know their intended functions/inputs/outputs,etc.. if nothing is visibly damaged..
30,887
That is a very sophisticated drive with firmware processors, unless the fault is in the power output section components, you may have a problem.
